Axis Fuzz shrinkage
Axis Fuzz shrinkage
Thinking about putting my Axis Fuzz in a small enclosure with just the volume pot since I keep the fuzz up and use the guitar's volume to adjust the fuzz. Is this possible without messing something up?!
- Xplorer
Re: Axis Fuzz shrinkage
Ok, I have not done this before so if you can point me in the right direction, I don't mind reading up on it.
- Xplorer
would you sell me the axis fuzz enclosure ? i'm currently building one.
i'd suggest to simply use a trimmer instead of the fuzz pot , but one side will have to be connected to the chassis enclosure ( as well for the pot you'll use ) , to get the ground.
the jacks grounds will also need the enclosure, to get the ground.
just do exactly as what you have now, but with a trimmer instead of your pot, same value, using the same connections as for the fuzz pot. that's all.
I have to hold on to this enclosure, it's special! Thanks for the info,that's what I needed to know.
