EP3 Preamp pedal build
Posted: Sun Jun 29, 2014 5:35 pm
by bwgintegra
Had most of these parts for a couple years and finally built an Ep-3 preamp circuit in a pedal. Turned out really cool. I have been tweaking it the last couple weeks and added a toggle to switch in a bypass cap. It really doesn't boost the signal much but adds a nice fatness to the tone. Found it works really good with single coil pickups. I'm currently running it at 18v with two 9v batteries in series but have ordered parts to build a charge pump that will let me run it off a normal 9vdc PS.
Re: EP3 Preamp pedal build
Posted: Sun Jun 29, 2014 5:39 pm
by bwgintegra
New pic with the charge pump circuit added using a LT1054 and 1N5818 schottky diodes. I can use a 9vdc PS and the charge pump provides about 18.5vdc to the ep3 circuit. This is like the charge pump Clinch EFX uses on his pedal. I gathered a lot of information he provided here for my circuit.
Posted: Mon Jun 30, 2014 9:32 am
by guitar007
Sweet pedal! How does it compare to an EP3?
Posted: Wed Jul 02, 2014 3:43 pm
by Haze13
Try "Paper in Oil" or Polypropylene Film and Foil (like wima FKP2) for the caps and sk170bl or sk246bl for the transistor. You won't be disappointed in the result. Like New Strings vs Old Strings...
Posted: Fri Aug 08, 2014 8:52 am
by bwgintegra
guitar007 wrote:Sweet pedal! How does it compare to an EP3?
Never played a real EP3 but this pedal has become permanent on my pedalboard. Thinking about doing another one with some different components.
Posted: Fri Aug 08, 2014 8:53 am
by bwgintegra
Haze13 wrote:Try "Paper in Oil" or Polypropylene Film and Foil (like wima FKP2) for the caps and sk170bl or sk246bl for the transistor. You won't be disappointed in the result. Like New Strings vs Old Strings...
Thanks for the information, think I might give this a go!
Posted: Fri Mar 13, 2015 11:52 pm
by jnew
These pedal types are fakking awesome.
Posted: Thu Jun 09, 2016 9:35 am
by fixer2
Can you put a picture of the back side of the board I like to see were the jumper wires go or I am looking for a layout of all the components in this build I want to make one I got the parts from valvestorm but there pic I can not get to a readable size on my computer looks like you a great neat job
