one spot
one spot
just curious what you all think about the one spot 9V power wall wart for powering my entire pedal board. Thks
Re: one spot
The 1Spot is at first glance a good and cheap solution to a multi pedal board. However, believe it or not, a 9VDC supply like the single 1Spot can cause 9VDC GROUND LOOPS between pedals. This is something you thought was only possible with multiple AC amp use but now you know otherwise. So you need an isolated 9VDC supply or at least many 9V split Y cables with only one ground path of the 9V connected. The reality is the ground of your guitar cables (between the pedals) serves as a conductor of the 9V ground going to your pedals. If all your 9V cables (positive and negative) connections are made, then your guitar cables between your pedals are also conducting a ground reference and therefore NOISE. It's science.
Re: one spot
I had to stop using my 1spot becuase of the noise. Is there a way to get rid of the noise because it works great but noisy thksRetsoor wrote: ↑Mon Oct 26, 2020 4:43 pmThe 1Spot is at first glance a good and cheap solution to a multi pedal board. However, believe it or not, a 9VDC supply like the single 1Spot can cause 9VDC GROUND LOOPS between pedals. This is something you thought was only possible with multiple AC amp use but now you know otherwise. So you need an isolated 9VDC supply or at least many 9V split Y cables with only one ground path of the 9V connected. The reality is the ground of your guitar cables (between the pedals) serves as a conductor of the 9V ground going to your pedals. If all your 9V cables (positive and negative) connections are made, then your guitar cables between your pedals are also conducting a ground reference and therefore NOISE. It's science.
Re: one spot
I have one the multiple one I think it has like 12 spots.. Mine is good - no noise... I love it !
