Hey guys,
Will a rangemaster sound bad if I put in a trimpot instead of the regular ol' metal film resistor? I'd like to bias it correctly but not have to replace the trimpot, since I do not have a surplus of parts/good supplier of metal film resistors (the blue ones).
zoom...
*ptwang*
Trimpots in Rangemasters
- Herec
- jerrydyer
rangemaster
Yes use the trim pot. there is a guy on this site who has built a lot of them and that is what he recommends to get it right Two trim pots actually. there are two different spots where you can dial in the exact flavor you like then finalize it with a resistor.
- stoo
- Herec
- stoo
I have no idea BUT..there is a DIY project called the Thunderchief..
http://runoffgroove.com/thunderchief.html where they have several trimmers in the circuit permanently. Personnally I'd say ..in a high gain circuit you'd want low noise resistors ie. metal film. But whay do Im know!!
stew
stew
trim pots in range masters
Trim pots cost alot more than resistors. And unless you have the multi turns can be a bitch to dial in. If you are using pad per hole perf, or have a board try using sockets.
