I REALLY miss my reverb
- Bad Kitty
I may be missing something but is there a way to get some reverb AFTER the amp.
Like an attenuator but with an effects loop.
I have a couple of rack processors that I tried in the front end but they're digital and sound like it too.
When you get that good cranking distortion in the power section an effects loop would distort the reverb too, wouldn't it?
Mike
Mike
Never settle for an amp thats smaller then you are.
- TomGibbs
- Bad Kitty
Thanks, blfrd but since that goes into the front of the amp it will distort right along with my guitar. What I'm looking for is distorted guitar, clean reverb.
Just out of curiosity though how much are you looking to get for it?
I might have to go the re-amping route. Shit, this whole amp thing is getting expensive
Mike
Mike
Here's the info on it:
http://www.vanamps.com/reverbamate.html
and a pic:
specs:
Dwell and Output controls
Reverb and Direct outputs
Accutronics
and a pic:
specs:
Accutronics
If there's no quiet, there can be no loud.
- Tone Slinger
I have heard that brotha' Ed ran a tube echoplex in the front of his amp to get a little more boost and ambiance. The analog type delay's can come close to giving you a reverb type sound. Maybe try a EH Holy Grail or somethin', unless you wanna get a tube Fender reverb knockoff $$$. You are probably right about the distorting power tubes messing up front and loop effects, but try as much as possible.
I've heard that too, but can't see how it could be true. With the way Ed ran his amps (wide open), I would imagine that would be very noisy.Tone Slinger wrote:I have heard that brotha' Ed ran a tube echoplex in the front of his amp to get a little more boost and ambiance. The analog type delay's can come close to giving you a reverb type sound. Maybe try a EH Holy Grail or somethin', unless you wanna get a tube Fender reverb knockoff $$$. You are probably right about the distorting power tubes messing up front and loop effects, but try as much as possible.
If he were using it as a boost (with the echo down or off) then it *might* have worked.
But I can't see how it would have worked. If he wanted a boost, why didn't he just get some other FET boost or something.
- 908ssp
I run an analog delay into my second channel that gives me that fullness and since the second channel can run at a lower volume then the high gain bright channel it doesn't add distorsion to the slap back echo.
What I do is split the cord running from my board with one lead going to the high gain bright input and the other going to the delay and from the delay back to the high gain normal input.
I've also heard this works well, but haven's tried it. Does it work better than running to a dummy load then to the effects then to another amp?908ssp wrote:I run an analog delay into my second channel that gives me that fullness and since the second channel can run at a lower volume then the high gain bright channel it doesn't add distorsion to the slap back echo.
It's certainly less gear!
got any clips of this setup?
- Riscchip
- 908ssp
No I wouldn't say it sounds better. It certainly sounds adequate. Like you said a lot less gear and a fairly simple setup but also more limited. Of course if you know that a simple slap back is all you want you have to ask yourself if all the rest is worth it? I used an Ibanez AD9 last night and it sounded well nearly indistinguishable from the Maxon and cost less then half. I made a Y cable with one lead longer then the other so that it would reach to the top of the amp and the pedal without trying to drag the pedal off the top of the amp. Now the setup is done. Works great sounds terrific. You could do the same with a reverb pedal but I prefer delay.blfrd wrote:I've also heard this works well, but haven's tried it. Does it work better than running to a dummy load then to the effects then to another amp?908ssp wrote:I run an analog delay into my second channel that gives me that fullness and since the second channel can run at a lower volume then the high gain bright channel it doesn't add distorsion to the slap back echo.
