Here is an interesting read...
http://www.guitaramplifierblueprinting. ... verter.pdf" onclick="window.open(this.href);return false;
What do folks think?
Phase Inverter Tube
- rgorke
Phase Inverter Tube
Re: Phase Inverter Tube
When pushing "everything on 10" every single tube is important, pre and poweramp
I do not agree with him that you should change the PI tube every time you change power tubes. Yes it is true that the PI is overdriving but they simply do not run as hot and work as hard as your power tubes do. I have tested many PI tubes and other preamp tubes in my amps after several cycles of power tube changes and they still test strong.
+1danman wrote:I do not agree with him that you should change the PI tube every time you change power tubes. Yes it is true that the PI is overdriving but they simply do not run as hot and work as hard as your power tubes do. I have tested many PI tubes and other preamp tubes in my amps after several cycles of power tube changes and they still test strong.
- JimiJames
+1
the Phase inverter being the most important tube in your amp.
He mention's some general things, but sounds more from his personal point of view more thanMyles S. Rose wrote:"...What do I like?"... // ...."Not from my personal taste..."
- rgorke
I threw a vintage 5751 in my PI and it seemed to tighten things up a bit and bring some clarity to the tone. If that makes any sense.
- Location: Various venues earning money to pay off gear LOL
Yea I like the Jan Sylvania 5751 in the PI of my 2210.
74' Stratocaster
Several Frankenstrats
Orange Tiny Terror & PPC 1x12 cab
Marshall 2210
69' Marshall 4x12 "B" cab
Dean Markley CD-60
Marshall 2210
Dean Markley CD-60
- JimiJames
Not everytime.
danman wrote:I do not agree with him that you should change the PI tube every time you change power tubes...
Myles S. Rose wrote:"...think about a simple phase inverter change..."
Myles S. Rose wrote:"...Before you go to a pricy output set of tubes..."
