My Hickok Model 539C Tube Tester
Posted: Sat Aug 16, 2014 5:10 pm
For all those who buy vintage tubes that sellers claim to be strong and "like new" or "NOS" and then realize you purchased a dud I say get yourself a tube tester!
Here is my 1963 Hickok 539c. A beautiful piece of test equipment hand wired and built extremely well. I have owned it for some time now and am in the process of re-calibrating it. This time around though I replaced the 83 Mercury vapor rectifier tube with a solid state replacement. Easy to construct using a few diodes and a 4 pin tube socket, I added a large aluminum heat sink to the tube bracket where I then attached the necessary 2.5ohm wire wound resistor. This will reduce the heat otherwise generated by the 83, as well as eliminate the stress that the 83 put on the transformer. I have a 3.3ohm resistor staged on the heat sink as well just in case I want to eventually replace the 5Y3GT tube.
This mod can easily be reversed as no permanent holes were drilled.
I also finally replaced a few of the capacitors that were way out of tolerance - this has been a fun project and having a fully calibrated vintage 539c is the best way to weed out the good eggs from the bad
