12AX7, 7025, cv4004, etc....??
- 5150loveeddie
Larry or anyone, can you tell me what means those numbers on 12ax7s ex. a GE 7025? What are the caracteristics/differences between those numbers...???
Thanks!!
Thanks!!
- novosibir
Once upon a time
some decades ago, there definitely was a difference between the 12AX7/ECC83 and the 7025 - not a difference in their electrically parameters, but a difference in the construction.
The 12AX7 was made for usual use, while the 7025 (that's a US industrial number) was more rugged in its construction, to withstand a higher amount of vibrations, which might occur when used in some machines, medical equipment, cars, planes, aso.
Therefore the 7025 always was lower in microphonics compared to the usual 12AX7 - and therefore this tube was recommended as the input tube in guitar amps.
But meanwhile there's no difference anymore with the current produced preamp tubes, no matter how they are labelled.
Larry
Larry
- 5150loveeddie
Larry you are a great addition to our community here, you rock coach, thanks for the crash course on NOS 12ax7s....novosibir wrote:Once upon a timesome decades ago, there definitely was a difference between the 12AX7/ECC83 and the 7025 - not a difference in their electrically parameters, but a difference in the construction.
Larry
George we should add a NOS tubes topic, there is so to learn, this would be a great addition to the board.........
- 5150loveeddie
Larry, I can't find the thread on 161s and 163s
Which one is more rock and roll again, the 163 right?
- novosibir
Right! But I63 (a capital "i")5150loveeddie wrote:Which one is more rock and roll again, the 163 right?
Larry
- 5150loveeddie
Oh yeah really it an "I" there not a one ??novosibir wrote:Right! But I63 (a capital "i")5150loveeddie wrote:Which one is more rock and roll again, the 163 right?![]()
Larry
