Willing to draw up Marshall 4x12 blueprints
Re: Willing to draw up Marshall 4x12 blueprints
From what I saw, he normally uses veneered particle board for cabinets these days, but he had the BB ply there in about 2 days.
PM sent with prices.
Cool thread. Anyways, 5/8 Baltic birch or Russian birch is expensive. I can get it for about 55 per 5x5 sheet. It's high quality, uses better glue and has few or no voids within the sheet-not like your big box store plywood. 5/8 should give excellent tone and be much lighter than 3/4/. The best way to attach side to top and bottom would be either box or dovetail joints using a jig. Something similar to a Keller jig with a router. I would not suggest using drywall screws. Instead go to McFeelys and get some cabinet screws and some trim washers for attaching the backs and then to Reliable hardware company for the handles, jacks and what not. Titebond should be all you need for glue. If you have a tablesaw, great! Get a helper to grab the wood as it comes off the back of the saw-safety first. If not, you could do it with a circular saw,straightedge and a couple saw horses. to make the speaker holes, use a plunge router with a circle cutting jig. If your good at it, you could probably make some money at it.
drat! curses! megaupload has been seized by the FBI brain policia.
it's time to repost them i thinkTazin wrote:Ok, now that phase one is somewhat complete here's the revised blueprint. Once again, corrections and suggestions are always welcome.
http://www.megaupload.com/?d=4U2XBHTD" onclick="window.open(this.href);return false;
Yes....Please someone re post.
Ok, I'll see what I can do.
Hopefully this works. https://rapidshare.com/files/1434496960 ... tr_Cab.pdf" onclick="window.open(this.href);return false;
One of these days I'll get off my ass and post the matching slant cab 1960a blueprints too.
super nice of you man ! but ... rapidshare don't work with me ... imageschack would be far better i think ( plus it's freeTazin wrote:Hopefully this works. https://rapidshare.com/files/1434496960 ... tr_Cab.pdf" onclick="window.open(this.href);return false;
As in the link is no good, or is your country blocking the use of rapidshare? PM me with your e-mail addr and I'll send you the file. In addition, I'll look into imageshack also.frenchie wrote:super nice of you man ! but ... rapidshare don't work with me ... imageschack would be far better i think ( plus it's freeTazin wrote:Hopefully this works. https://rapidshare.com/files/1434496960 ... tr_Cab.pdf" onclick="window.open(this.href);return false;
One of these days I'll get off my ass and post the matching slant cab 1960a blueprints too.)
i think my country is possibly blocking the link yeahTazin wrote:As in the link is no good, or is your country blocking the use of rapidshare? PM me with your e-mail addr and I'll send you the file. In addition, I'll look into imageshack also.frenchie wrote:super nice of you man ! but ... rapidshare don't work with me ... imageschack would be far better i think ( plus it's freeTazin wrote:Hopefully this works. https://rapidshare.com/files/1434496960 ... tr_Cab.pdf" onclick="window.open(this.href);return false;
okay , here it is accessible for everybody
http://pdfcast.org/pdf/4x12-straight-plans" onclick="window.open(this.href);return false;
thanks tazin
thanks tazin
Rapidshare link worked fine for me...Thanks!!!
Any chance of reposting the plans as none of the links work now. Many thanks.
Hello
Does someone have this plans?
All links are broken
Thank you so much
Thank you so much
