Mounting Speakers - How Tight?
rgalpin
Post by rgalpin » Fri Mar 23, 2007 8:26 pm
When you mount speakers do you tighten the screws until the metal frame of the speaker touches the wood? or do you stop short of that?
thanks!
bmf5150
Post by bmf5150 » Fri Mar 23, 2007 9:20 pm
i just do them snug in an x pattern,you dont want to twist the frames,then you get voicecoil rub.
My EVH sound clips.
jnewlyn
Post by jnewlyn » Sat Mar 24, 2007 8:22 pm
I'd think that you want to squish the cork or padding pretty evenly with all four screws. Evenly and with enough torque to safely secure the speaker but definitely avoid twisting or mis shaping the frame as it won't be flat and true.
Cheers to the ears.
Myopic Void
Post by Myopic Void » Sun Mar 25, 2007 9:41 pm
Just snug. I see some cabs were they are just too tight and it flattens out the corkboard.
Cheers,
Eric
Scumback Speakers
Supporting Advertiser
Post by Scumback Speakers » Sun Mar 25, 2007 11:54 pm
Tighten them with your fingers until the screw meets the back of the frame, then use a screwdriver to tighten them 1/2 to 1 full turn more.
rgalpin
Post by rgalpin » Mon Mar 26, 2007 7:52 am
8) thanks!
rgalpin
Re:
Post by rgalpin » Wed Jun 13, 2012 8:14 pm
Scumback Speakers wrote:Tighten them with your fingers until the screw meets the back of the frame, then use a screwdriver to tighten them 1/2 to 1 full turn more.
5 years later... and here is the answer I needed... AGAIN. Thank you Mr. Scumback Speakers! :hairband: :rock:
