Hey Jim (Scumback) any 10"s coming?
- jbzoso2002
Are you going to be macking any 10" speakers. like pvc greenback?
Jimmy
Jimmy
- Scumback Speakers
- Supporting Advertiser
Re: Hey Jim (Scumback) any 10"s coming?
No plans to make 10's till the initial order of frames is less than 600 (200 of each type I'd need). And I doubt I'd make 10" PVC models since the power handling would be about 10-15w each.
- Mars Hall
Jimmy, what are you needing 10" speakers for?
- jbzoso2002
Mars Hall wrote:Jimmy, what are you needing 10" speakers for?
Im sorry Jerry, I can talk to you anymore, your house is to big.
My Class 5, I got some caps & resistors for it & id like a low watt 10" for it.
Jimmy
Those Celestion G10L-35s are killer. Jim, didn't you say you had a set?
- Mars Hall
I still have my little house too... Hopefully not to much longer.jbzoso2002 wrote:Mars Hall wrote:Jimmy, what are you needing 10" speakers for?
Jimmy
What ohmage do you need? I have a ceramic mag Emmy at 8 ohm you could try. It was in my 70 SFSR when I got it. It's only one million dollars...
Are you stiffening the power supply on the amp?
- Scumback Speakers
Never had a set of G10L-35's. They weren't my idea of good 10" tone, sorry.SteadyEddie wrote:Those Celestion G10L-35s are killer. Jim, didn't you say you had a set?
Ooops, I meant G10 greenbacks. Had a total brain fart there. I replaced my G10L-35s with G10 greenbacks in my 1965a cab.
