How to remove the JCM800 badge to replace grillcoth?
How do you remove the JCM800 badge to replace the grillcloth?
My first project: 1959HW to 12xxx Courtesy of the Late Great Rockstah a.k.a. Edward Van Abrahamian
- Scumback Speakers
- Supporting Advertiser
Re: How to remove the JCM800 badge to replace grillcoth?
If memory serves me right, it's glued and stapled in. In other words, you ruin it taking it off. Replacements available from http://www.tubesandmore.com" onclick="window.open(this.href);return false;vkaxeman wrote:How do you remove the JCM800 badge to replace the grillcloth?
Scumback Speakers wrote:If memory serves me right, it's glued and stapled in. In other words, you ruin it taking it off. Replacements available from http://www.tubesandmore.com" onclick="window.open(this.href);return false;vkaxeman wrote:How do you remove the JCM800 badge to replace the grillcloth?
"ruin it", bummer! - Thanks for the link. But.... searching that site and others and not finding a JCM800 badge. Found a JCM900 badge and a few others. Hmmm, maybe I will just leave the old original grill cloth on it.
Thanks for the quick reply and info Jim!
I just put new cloth on a 90's JCM 900 cab . . . the badge on mine had adhesive glue only . . . I heated it up with a hair dryer and took a razor blade to very carefully lift one edge. Once I got one edge lifted, I slowly worked the blade into the other side until I got about halfway at which point the badge popped off.
Kind of need the same amount of patience you use to peel off a price tag on something in one fell swoop, rather than if you just go at it and tear or have residual adhesive.
sixpakldp wrote:I just put new cloth on a 90's JCM 900 cab . . . the badge on mine had adhesive glue only . . . I heated it up with a hair dryer and took a razor blade to very carefully lift one edge. Once I got one edge lifted, I slowly worked the blade into the other side until I got about halfway at which point the badge popped off.
Cool! Thanks for the info! - I will give that a try.
Did you put black grill cloth back on it and were you able to find the exact Marshall Black Grillcloth?
I changed the style of grill cloth . . . went from the original black to the checkered cloth. Try mojotone . . . I believe they buy their cloth from Marshall, here is their black cloth
http://www.mojotone.com/amp-parts/ampli ... Cloth-58-W" onclick="window.open(this.href);return false;
If you have any doubts, give them a ring. They are very helpful over the phone.
Hope this helps.
Hope this helps.
- Scumback Speakers
Was cleaning up some old boxes and found a JCM 800 badge off of an old 4x12 I recovered. It's got a gold plate glued into black plastic frame. The frame screws into the baffle board, the plate gets glued on afterward.
So you would have had to pull/yank/knock it out from the back of the baffle board. Doubtless they had many ways there were attached over the years.
But if anyone needs one shoot me an email...not a PM...an email.
