16 Ohm ??
Jerry G
16 Ohm ??
Post by Jerry G » Sun Jan 06, 2013 12:25 pm
I am sure this has been covered before but wouldn't know ho to search this.
Why are speakers that are supposed to be 16 ohm 13.2 ohm? I assume I run the amp on the 16 ohm selector?
Jerry G
62sg
Re: 16 Ohm ??
Post by 62sg » Sun Jan 06, 2013 12:28 pm
Yes, run the amp @ 16.
JOHN
Jerry G
Re: 16 Ohm ??
Post by Jerry G » Sun Jan 06, 2013 2:12 pm
62sg wrote:Yes, run the amp @ 16.
Thanks, I thought it was bad to have a lower impedance on the load end instead of the other way around.
62sg
Re: 16 Ohm ??
Post by 62sg » Sun Jan 06, 2013 2:18 pm
That's true...you could actually run the amp at 8 & be ok. But you wouldn't want to use an 8 ohm cab and have your amp set to 16.
JOHN
julkke
Re: 16 Ohm ??
Post by julkke » Sun Jan 06, 2013 2:20 pm
Speakers read lower when measured with a multimeter
Jerry G
Re: 16 Ohm ??
Post by Jerry G » Sun Jan 06, 2013 2:21 pm
:thumbsup:
Coot Boy
Re: 16 Ohm ??
Post by Coot Boy » Mon Jan 07, 2013 12:24 am
Jerry G wrote:I am sure this has been covered before but wouldn't know ho to search this.
Jerry G
Impedance and resistance are two different things. Google is your friend.
demonufo
Re: 16 Ohm ??
Post by demonufo » Mon Jan 07, 2013 4:32 am
In brief, impedance is equivalent to the average resistance at ALL frequencies. Your multimeter is a set frequency/voltage.
So I like purple, okay!!!!!!
Scumback Speakers
Supporting Advertiser
Re: 16 Ohm ??
Post by Scumback Speakers » Mon Jan 07, 2013 9:22 am
Here's the real answer for you. Voice coils are spec'd lower than their rating. Why? Because when they heat up the impedance also goes up.
My 16 ohm coils are wound for 13.2 - 13.4 ohms, and the 8 ohm models are wound for 7.2 ohms.
When current/signal (electricity) is run through the coil, it heats up. To get the rating somewhat close to 16 when at operating temperature it has to be wound to a lower value.
Hope that helps!
Jim
demonufo
Re: 16 Ohm ??
Post by demonufo » Mon Jan 07, 2013 9:41 am
Well, that's another reason for sure. But in reality, resistance is completely irrelevant, and is not truly comparible either way.
Coot Boy
Re: 16 Ohm ??
Post by Coot Boy » Mon Jan 07, 2013 3:28 pm
Resistance is futile.
demonufo
Re: 16 Ohm ??
Post by demonufo » Mon Jan 07, 2013 4:03 pm
Actually, in regards to the same amount in either direction, it is potentially worse to have a higher load than setting.
Jerry G
Re: 16 Ohm ??
Post by Jerry G » Wed Jan 09, 2013 2:19 pm
Thanks for all the good info, you guys are huge help and I appreciate it. :thumbsup:
Maverick
Re: 16 Ohm ??
Post by Maverick » Sun Jan 13, 2013 4:27 pm
Another little tidbit of info!!!!
The dc resistance of a speaker will increase with movement in the room or shutting and closing of a door
use a multimeter and measure your cab and have a freind open the door and watch what happens
THE DC RESISTANCE CHANGES. THERE IS NO CURRENT.
Akme Guitars
demonufo
Re: 16 Ohm ??
Post by demonufo » Mon Jan 14, 2013 4:44 am
That's not strictly true. You won't actually be able to measure such a phenomenon with a multimeter, because what is actually happening is the speaker is GENERATING electric current. Therefore the resistance will give you some odd readings.
