16 Ohm ??
Posted: Sun Jan 06, 2013 12:25 pm
by Jerry G
I am sure this has been covered before but wouldn't know ho to search this.
Why are speakers that are supposed to be 16 ohm 13.2 ohm? I assume I run the amp on the 16 ohm selector?
Jerry G
Re: 16 Ohm ??
Posted: Sun Jan 06, 2013 12:28 pm
by 62sg
Yes, run the amp @ 16.
Re: 16 Ohm ??
Posted: Sun Jan 06, 2013 2:12 pm
by Jerry G
62sg wrote:Yes, run the amp @ 16.
Thanks, I thought it was bad to have a lower impedance on the load end instead of the other way around.
Re: 16 Ohm ??
Posted: Sun Jan 06, 2013 2:18 pm
by 62sg
That's true...you could actually run the amp at 8 & be ok. But you wouldn't want to use an 8 ohm cab and have your amp set to 16.
Re: 16 Ohm ??
Posted: Sun Jan 06, 2013 2:20 pm
by julkke
Speakers read lower when measured with a multimeter
Re: 16 Ohm ??
Posted: Sun Jan 06, 2013 2:21 pm
by Jerry G
Re: 16 Ohm ??
Posted: Mon Jan 07, 2013 12:24 am
by Coot Boy
Jerry G wrote:I am sure this has been covered before but wouldn't know ho to search this.
Jerry G
Impedance and resistance are two different things. Google is your friend.
Re: 16 Ohm ??
Posted: Mon Jan 07, 2013 4:32 am
by demonufo
In brief, impedance is equivalent to the average resistance at ALL frequencies. Your multimeter is a set frequency/voltage.
Re: 16 Ohm ??
Posted: Mon Jan 07, 2013 9:22 am
by Scumback Speakers
Here's the real answer for you. Voice coils are spec'd lower than their rating. Why? Because when they heat up the impedance also goes up.
My 16 ohm coils are wound for 13.2 - 13.4 ohms, and the 8 ohm models are wound for 7.2 ohms.
When current/signal (electricity) is run through the coil, it heats up. To get the rating somewhat close to 16 when at operating temperature it has to be wound to a lower value.
Hope that helps!
Jim
Re: 16 Ohm ??
Posted: Mon Jan 07, 2013 9:41 am
by demonufo
Well, that's another reason for sure. But in reality, resistance is completely irrelevant, and is not truly comparible either way.
Re: 16 Ohm ??
Posted: Mon Jan 07, 2013 3:28 pm
by Coot Boy
Resistance is futile.
Re: 16 Ohm ??
Posted: Mon Jan 07, 2013 4:03 pm
by demonufo
Jerry G wrote:62sg wrote:Yes, run the amp @ 16.
Actually, in regards to the same amount in either direction, it is potentially worse to have a higher load than setting.
Re: 16 Ohm ??
Posted: Wed Jan 09, 2013 2:19 pm
by Jerry G
Thanks for all the good info, you guys are huge help and I appreciate it.
Re: 16 Ohm ??
Posted: Sun Jan 13, 2013 4:27 pm
by Maverick
Another little tidbit of info!!!!
The dc resistance of a speaker will increase with movement in the room or shutting and closing of a door
use a multimeter and measure your cab and have a freind open the door and watch what happens
THE DC RESISTANCE CHANGES. THERE IS NO CURRENT.
Re: 16 Ohm ??
Posted: Mon Jan 14, 2013 4:44 am
by demonufo
That's not strictly true. You won't actually be able to measure such a phenomenon with a multimeter, because what is actually happening is the speaker is GENERATING electric current. Therefore the resistance will give you some odd readings.
