Mikelib wrote:Thanks for all the tips. I will take a look at reversing the cloth and see if it is workable. I have never done this before so I don't really know how these cabs are put together. Does anyone know of any step by steps online on how to dismantle a cab? I would hate to mess it up. Even though the cab isn't the prettiest It means a lot to me as I haven't heard a cab that sounds as good. I'm not even sure how to remove the Marshall logo without snapping it. First step I think is to take a closer look at the white stuff on the cones and figure out how to wire the speakers.
1) Original Marshall wiring looks like this:
http://www.amparchives.com/album/Marsha ... nside.html
The gauge of wire is up to you but 16 or 18 swg is fine
2)
http://theogre.home.bresnan.net/images/ ... rallel.jpg
3) To remove the baffle, first you remove the back board and the handles (the T nuts can stay if they are well pulled into the wood of the sides).
Remove the speakers for inspection (always lie them face down).
Remove the internal screws that go through the wooden mounting flange using a POZIDRIVE screw driver. You can use a Phillips but don't be surprised if you chew the screws up (they are often
very tight) in fact an impact driver can be useful sometimes, do take care to use the right bit!!
The baffle will now move and you can tilt it backwards and then angle it to slide it out through the angled slots in the back board support. You can now inspect through the speaker holes and inspect for paint bleed through. The basketweave is secured to the baffle by hundreds of narrow head staples - a really tedious job but has to be done correctly. If you do flip pyou must rotate the weave through 90 degrees too to get the threads to run correctly (otherwise it will be lined up like a Hiwatt) Alternatively a new S&P cloth might be in order. It is a different material to the original but IMO looks ok - might be a bit odd when the cab levant is tatty. IMO I prefer the old stuff looking tatty and the original cloth but YMMV!
Reassembly is a reverse.
I always try to preserve the original screws as new ones always look out of place (and a sure sign of tampering later). Mpst back screws have been horribly abused and are often missing. George used to sell correct domed Pozi replacements, not sure if there is a more up to date source now?
