Hi everyone,
I'm the proud and recent owner of a pre rola Celestion Greenback quad (1969!). Everything seems fine but the "terminal solder" is broken on all of the 4 speakers. I'm searching for another one desperately ! Do you know where i can buy some ?
Thanks for your help really appreciate,
Regards,
Max
Need HELP ! Celestion Greenback terminal solder
- Scumback Speakers
- Supporting Advertiser
Re: Need HELP ! Celestion Greenback terminal solder
OK, I'm confused...exactly what part/solder do you need? Do you have a picture of what you're missing?
It's the two little "hook" (one for the postive and one for the negative) as you can seen on the picture :
http://hpics.li/7439a5f
Scumback Speakers wrote:OK, I'm confused...exactly what part/solder do you need? Do you have a picture of what you're missing?
- Scumback Speakers
No one has those for sale. Yes I have spares for MY pre rolas, but no, you can't buy them.
Find an old Celestion frame, drill out the rivets for the wire terminal tabs, and mount them in your frames. You'll probably have to go with gray ones, black ones are really rare.
Good luck!
Good luck!
Does anyone sell the rivets?
Neatest way is to get these:
http://www.autoelectricsupplies.co.uk/p ... category/2
You can screw or rivet these to your existing card and solder to them quite easily.
Most duff speakers have been robbed of the terminals or the terminals are broken (at least in my experience!)
