New build,very low volume output
Homebelly
Post by Homebelly » Mon Nov 08, 2010 2:15 am
Just finished my first build.
Very satisfying experience.
Biased and plugged in and the out put volume is very low and distorted.
I'm guessing about 1/3 what it should be.
Where do i start looking for bugs?
Some of my toonz. http://soundcloud.com/sets" onclick="window.open(this.href);return false;
My stuff; two strats, one with Van Zants, the other with Fralins. A Jazz bass. One PRS McCathy gold top.
OnTheFritz
Re: New build,very low volume output
Post by OnTheFritz » Mon Nov 08, 2010 3:40 am
Most likely the 470 ohm resistor between the two 1 megs going to V3. Like a lot of people, you most likely put in a 470K.
Check that out.
Homebelly
Post by Homebelly » Mon Nov 08, 2010 7:54 pm
Cheers Mr Onthe fritz...
I'll take a look at that little bugger later on tonight.
I did a search of the forum last night and came across that as a common mistake, but most described noise and hums as symptoms so i passed that by...
