I've been using my JTM45 for about a year now and It it pretty amazing but recently it as been blowing the 3A fuse almost every time I flip the standby switch off. I know I need new power tubes but could that be causing the problem?
Jtm45 blowing fuses
Re: Jtm45 blowing fuses
Yes a shorted output tube could, usually a short would cause the HT to go, more likely your rectifier tube is out
- toner
Standby switches (at least the way most are wired, including JTM 45's) stress rectifier tubes. I don't use the standby on tube-rectified amps.
more info:
http://www.freewebs.com/valvewizard1/standby.html" onclick="window.open(this.href);return false;
more info:
