Post
by Mynameisfritz » Thu Nov 03, 2011 2:37 pm
Toner - man, I made it! It’s running!
I guess you’re right concerning the filter cap. And I guess that the reason for the dropping voltage was me, accidently switching both switches on one time, so the cap had been charged and what I measured was the dropping voltage afterwards, while ‘Stand By’ was off again. I went for a walk this afternoon and thought that this voltage drop is typical for a discharging cap, not for a tube. So I checked again, went on testing and everything worked out fine. I have 436V on the plates now. All other voltages are alright too – except on V1 where I have 196V on pin1 and 211V on pin6… well. I hope this is no serious problem.
The amp is running now with 3 ECC83 Phillips Miniwatt – which I found in an old bandecho together with some mustards-, 2 Shuguang KT66 and the Sovtek 5AR4. If everything stays fine with it, I’ll put in my GEC’s and a Siemens GZ34 and start tweaking.
It is a very clean build, yes, but to be honest - it had some issues too. The OT was mounted too close to the KT66’s, so I had to drill some new holes to put it further away. While doing this, I recognized that the cables of the OT had been glued to the chassis under the board… You never know…
But after all it is a fine amp now. Thanks so much for your help. I wouldn’t have made it all by myself.
