Loud pop when switching standby to off..
- wildebassman
I'm really happy with my JTM45 and all is working great but there's one thing that puzzles me. Sometimes when I've had the amp on, and stopped playing for a few minutes, when I switch the standby to off there's a loud pop. Is there a a way to cure this and what causes it?
Please help out.
Cheers,
Dennis.
Please help out.
Cheers,
Dennis.
Amps: JTM 45, JTM 50, under construction: JCM 2204. CAB: 2x12" G12H 30 55Hz. Heritage.
Re: Loud pop when switching standby to off..
Popping noise when going to standby? We all had popping noises when coming off of standby....
Do you have the 5.6k grid stoppers installed? Those fixed my amp!!! But my noise was the other way I guess.
Good luck
Good luck
- zrAC/DC
My amp has an occasional pop when turning the standby off, I'm not really too worried about it. I figured the only reason the amps squeals when turning the standby to on is the Valve Arts, my amp stopped doing it when I switched over to the Gold Lions, they are a whole different beast as far as sound goes.
~~Current Amps~~
1.) JTM45
--------Terawatt--------
http://www.reverbnation.com/terawatt" onclick="window.open(this.href);return false;
http://www.myspace.com/terawatts" onclick="window.open(this.href);return false;
1.) JTM45
Hey.
This is a common problem. What you need is what i think is called a "snubber" cap. It's a 0.047uF cap connected to the standby switch / pin 8 of the tube rectifier. This layout (from a competitors website) shows the way it's connected.
https://taweber.powweb.com/store/6m45_layout.jpg" onclick="window.open(this.href);return false;
Top left of the layout right at the standby switch to ground. It just suppresses the "back lash" you get when you switch the rectifier - which is what gives you the "thunk" through the speakers. You see this type of thing on tube rectified amps and also on JTM45/100's.
Wayne
Wayne
- LJay942
Mine does this too. I didn't think it was too big of a deal though. What voltage rating would you say for the capacitor on the standby swithc?
That's the B + so anything above this voltage value. 500v should do.
Wayne.
Wayne.
- wildebassman
Thanks, after searching the forum I also found a solution that is even simpler:
http://forum.metroamp.com/viewtopic.php?f=15&t=12881" onclick="window.open(this.href);return false;
Read Larry's (Novosibirs) input on the subject, pretty simple fix.
Thanks for the help guys!
Dennis.
Dennis.
Wayne wrote:Hey.
Wayne
w/r/t the "snubber cap" :
I had the popping problem when putting the amp into STBY before powering in off, and I solved it by REMOVING the .047uF "snubber cap", which I had soldered directly to the output (tube socket pin) of the rectifier and grounded on that tube sockets mounting screw, not to the STBY switch. Since I removed that cap, I've never had popping again. (Note:
my B+ is 410Vdc by design..I like the lower voltages in my amp. The cap was rated for 600 Vdc , AIR).
Moncler Outlet
Nike Outlet
Yeezy 500 Utility Black
Nike Black Friday 2020
Air Jordans Sneakers
Christian Louboutin
Nike Clearance Store
New Nike
Christian Louboutin Shoes
Nike Air Monarch
Christian Louboutin UK
Valentino Sandals
Nike Outlet Online
Nike React
Nike Cortez
Pandora Earrings
Pandora Official Website
Vans Shoes
Michael Jordan Shoes
New Shoes
Air Force 1
Jordan Shoes
Jordan 13 Retro
KD Shoes
Ultra Boost
New Nike Air Max 2019
Lebron 16 Shoes
Air Max
Nike Clearance
Adidas Yeezy
Jordan Shoes
Cheap Basketball Shoes
Nike Sneakers
Nike Air Max 270
Yeezy Shoes
Nike Sneakers Outlet
Nike Running Shoes For Women
Nike Basketball Shoes
Nike Huarache
Nike Outlet Online
Pandora Jewelry
Ferragamo Belt
Pandora Bracelets Charms
Nike Clearance Outlet
Pandora Charms
Nike Air Max 720
Pandora Jewelry
Stan Smith Adidas
Lebron James Shoes
Air Max 720
Jordan 11 Blue
NMD R1
Ferragamo
Lebron 16 Shoes
Lebron Shoes
Nike Shoes
Nike Store
Nike Website
Pandora UK
Pandora Bracelets
Nike Air Force 1
Jordans Sneakers
Nike Shoes For Women
Fjallraven Backpack
Pandora UK
Nike Air Force
Nike Store
Nike Zoom
Christian Louboutin Outlet
Nike Shoes
Nike Air Max 90
Air Max 98 Gundam
Nike Free Rn 2019
Asics Outlet
Louboutin Shoes
Nike Metcons
Red Bottom Shoes For Women
Nike Factory
Pandora
Nike Shoes
Kyries Shoes
Nike Factory
Pandora UK
Pandora Jewelry
Red Bottom Heels
Adidas Yeezy
Ferragamo Shoes
Yeezy Sneakers
Louboutin Shoes
Nike Outlet
Nike Air Max 98
Golden Goose
Louboutin Outlet
New Nike Shoes 2019
Pandora Necklaces
Pandora
Lebron 17 Graffiti
Nike Shoes
Pandora
Womens Nike Shoes
Nike Presto
Nike Factory Outlet
Christian Louboutin
Jordan Retro
Adidas Ultra Boost Men
Nike Outlet Store
Air Max 95
Nike Sneakers
Kyrie Shoes
Yeezy 700
Nike Shoes
Nike Factory Outlet
Yeezy Boost
Jordan Shoes For Kids
Red Bottoms
Nike Cortez Women
Louboutin Shoes
Air Force One Nike
Christian Louboutin
Cheap Yeezys
NMD Adidas
Christian Louboutin Shoes Outlet
Nike Air Zoom Pegasus
Air Jordan 11
Fjallraven Kanken Backpack
Nike Outlet Store
Cheap Nike Shoes
Yeezys Boost 350 V2
Yeezy
Adidas Sneakers For Women
Christian Louboutin shoes
Pandora
Nike Factory Outlet
Pandora Jewelry Rings
Nike Outlet
Christian Louboutin
New Nike
Nike Air Monarch
Valentino Sandals
Nike Outlet Online
Nike React
Nike Cortez
Pandora Earrings
Vans Shoes
New Shoes
Air Force 1
Jordan Shoes
Jordan 13 Retro
KD Shoes
Ultra Boost
Lebron 16 Shoes
Air Max
Nike Clearance
Adidas Yeezy
Jordan Shoes
Nike Sneakers
Nike Air Max 270
Yeezy Shoes
Nike Huarache
Nike Outlet Online
Pandora Jewelry
Ferragamo Belt
Pandora Charms
Nike Air Max 720
Pandora Jewelry
Stan Smith Adidas
Lebron James Shoes
Air Max 720
Jordan 11 Blue
NMD R1
Ferragamo
Lebron 16 Shoes
Lebron Shoes
Nike Shoes
Nike Store
Nike Website
Pandora UK
Pandora Bracelets
Nike Air Force 1
Jordans Sneakers
Fjallraven Backpack
Pandora UK
Nike Air Force
Nike Store
Nike Zoom
Nike Shoes
Nike Air Max 90
Air Max 98 Gundam
Nike Free Rn 2019
Asics Outlet
Louboutin Shoes
Nike Metcons
Nike Factory
Pandora
Nike Shoes
Kyries Shoes
Nike Factory
Pandora UK
Pandora Jewelry
Red Bottom Heels
Adidas Yeezy
Ferragamo Shoes
Yeezy Sneakers
Louboutin Shoes
Nike Outlet
Nike Air Max 98
Golden Goose
Louboutin Outlet
New Nike Shoes 2019
Pandora Necklaces
Pandora
Lebron 17 Graffiti
Nike Shoes
Pandora
Womens Nike Shoes
Nike Presto
Nike Factory Outlet
Christian Louboutin
Jordan Retro
Nike Outlet Store
Air Max 95
Nike Sneakers
Kyrie Shoes
Yeezy 700
Nike Shoes
Nike Factory Outlet
Yeezy Boost
Red Bottoms
Nike Cortez Women
Louboutin Shoes
Air Force One Nike
Christian Louboutin
Cheap Yeezys
NMD Adidas
Air Jordan 11
Nike Outlet Store
Cheap Nike Shoes
Yeezys Boost 350 V2
Yeezy
Pandora
Nike Factory Outlet
About this issue you can visit our website https://www.heisener.com/, there are professionals there to provide you with quick answers and professional programs, looking forward to your visit.
