2nd build JTM45 / BB cab
toneking
Re: 2nd build JTM45 / BB cab
Post by toneking » Thu Jul 12, 2012 7:34 pm
Thanks...i originally had the 500pf cap that was spec'd in the directions, but changed it up and settled on 100Pf
I was interested because I did the same thing. The 100pf seems to work best if you use a basic clean to semi-clean tone and get your overdrive sound through pedals, which is what I do to keep the volume in check. However, If I was going for natural amp overdrive the 500pf is the ticket.
I use a ceramic 100pf on both my JTM45 and my '67 spec shared cathode JMP50. I like the way a ceramic cap sound sounds, the silver micas seem a little harsh to me.
It's a nice build for sure!
Life's too short for bad tone!
JoeM
Post by JoeM » Thu Jul 12, 2012 11:29 pm
toneking wrote:Thanks...i originally had the 500pf cap that was spec'd in the directions, but changed it up and settled on 100Pf
The 500pf was was too bright for me even at higher volumes. I think its partly because my les paul has the 498t pup in it which is a bit hot. I just like the 100pf better all around at any volume. And if im playing it wide open(which i think we would all prefer) it doesn't really matter. I may try a 250pf in the future just because.
I havent had a chance to try the amp out in a band situation yet since im still waiting for my cabinet. I already have my scumback speakers....i picked up the BM75 blackbacks and have them in a 2x12 cab for now. I really like them! I also have some celestion g12c that are finally breaking in....they are quite a bit darker than the bm75. Im gonna post a few clips once i get my cab. It should be here soon. In the mean time ill keep playing around with the preamp tubes but im pretty happy with it right now. I have jan phillips 12ax7 in v1/ tungsol v2 /tungsol v3/ and gold lion kt66's
JoeM
Post by JoeM » Thu Jul 12, 2012 11:33 pm
neikeel wrote:Yes, very nice build 8)
Thank you. Hopefully ill have some clips up soon
toneking
Post by toneking » Tue Jul 17, 2012 1:47 pm
I'm running my JTM through a 2x12 cab with a pair of Celestion Silver Alnicos and it sounds great. It also sounds great through my 4x12 cab w/ Weber G12M copies.
JoeM
Post by JoeM » Sun Sep 30, 2012 9:57 am
Post by neikeel » Sun Sep 30, 2012 3:24 pm
Very nice 8)
shakti
Post by shakti » Sun Sep 30, 2012 4:05 pm
Yes indeed! Swanson also does excellent work as always. Nice touch with that grille cloth. Are you going to put a block logo on it?
axeman
Post by axeman » Sun Sep 30, 2012 4:19 pm
How much was the box?
JoeM
Post by JoeM » Sun Sep 30, 2012 4:26 pm
axeman wrote:How much was the box?
$450 + shipping
JoeM
Post by JoeM » Sun Sep 30, 2012 4:31 pm
shakti wrote:Yes indeed! Swanson also does excellent work as always. Nice touch with that grille cloth. Are you going to put a block logo on it?
The grill cloth was actually a mistake but i liked it and kept it. I was suppose to have re-issue bluesbreaker cloth but got reissue offset cloth.
If anything ill put a Metroamp logo on it. I need to email Dusty at metro again to see if there any left.
JoeM
Post by JoeM » Sun Sep 30, 2012 4:32 pm
neikeel wrote:Very nice 8)
Thanks...now i have to work on getting some decent clips up....
johan
Post by johan » Thu Nov 22, 2012 6:04 am
Looks awesome!
Just what I'm aiming for.
I have a JTM45 chassis ready to install. Built on a C-tone chassis w Marstran iron and Sozo caps.
Two q's
You think the Scumbacks are a good combination w the jtm45? I see you went for the more aggressive Blackbacks vs the Greenies.
I still need a cab. Since I'm in Europe I will have it made here. Do any of you have the correct dimensions for the BB cab? I'm using KT66, maybe they need some more space.
Post by neikeel » Thu Nov 22, 2012 7:15 am
I have a 2nd hand one you can have with speakers, some light dings in the levant only.
It is one of these:http://www.tubeampdoctor.com/en/shop_AM ... _Combo_862
Pair of golds?
pair of blackbacks?
pair of greenback Celestion T1886 with black/gold logos
one heritage G12H and one Gold combo works well too.
I am in the UK if seriously interested I will take pics for you.
