In the room, not on mic, I don't really even perceive the low end change, other than it's more accurate down there now in les paul neck position on low notes. It's not a mess, there's better clarity down there, more harmonically complex, less mud.Froumy wrote:Awesome test! Thanks. Mustards definitely better. Sozo's are still damn good.
I think you've raised your cutoff of frequency by about 10Hz. Shouldn't be noticeable, but who knows? I swapped at .002(800Hz) for a .02(80Hz)in a high gain design and it was absolutely horrible. Farty weak bass, no mids...
I can't help but wonder why there was less "rumble", more defined mids, and a higher volume with the mustards....Here's a half-baked wild guess.
A higher "ESR" or "L"(besides noise) can CUT down the audio signal. Could that be why the Sozo's sounded quieter? Possibly, but I'm thinking it's something else...
A cap with poor "Insulation Resistance", besides noise, can DAMPEN low frequency signals. That could account for the lack of "rumble" with the Mustards. Without wasted power amplifying the super lows, the amp could be more focused in the guitars range, where it's supposed to be. Maybe acting like a slight mid boost...Louder volume.
If that last one was right, I can't help but wondering why lowering the bypass cap(and so on) wouldn't produce similiar results with the Sozo's....
Just guessing gent's. Hopefully someone in the know will fill me in.....
I don't know about raising the cutoff freq by 10k, but what I can tell you about the top end, especially in the room with it, is that it's more pleasant and less piercing with the strat, which is always the challenge. The top end is just more musical.
What happened with the midrange is my favorite thing about the change. It's so open and pronounced and, someone said it, it centers right where the guitar is supposed to be, thinking mix wise. It's big without demolishing the spectrum around it being too wide. That's how those AC/DC tones sat so high in the mix without stomping on everything else. The mids sing now when you solo. It's heavenly to play through.
