JTM 45 amp kit instructions ***UPDATED*** Oct 2008
- VelvetGeorge
- Site Owner
JTM 45 kit instructions. 26Mb download in pdf format.
http://metroamp.com/downloads/JTM_45_KIT_V2.1.pdf" onclick="window.open(this.href);return false;
May 2014, I stuck this file in Dropbox.
https://dl.dropboxusercontent.com/u/646 ... CTIONS.pdf
- csteward
Re: JTM 45 amp kit instructions ***UPDATED*** Oct 2008
Thanks for the Update George
Thanks worked great. I'll tell ya the split turretts are VERY enjoyable to work with. It's also easy to do a nice neat job with them!
69 SuperBass Plexi
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
2550 Silver Jub stack
71 LesPaul Deluxe
68,71,73 4x12
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
71 LesPaul Deluxe
68,71,73 4x12
Is there any other way to get these instructions... my computer will not pull up that page for some reason...
Tried downloading the instructions this morning, and it's a no-go......it starts, but stops at about 850Kb.
Same with the 50 watt instructions..no-go.
- Administrator
Did you get the file? I tested it and it seems to be working. It's a big download, it will take some time.PCollen wrote:Tried downloading the instructions this morning, and it's a no-go......it starts, but stops at about 850Kb.
Ok I think I'm going nuts, I cannot see an instruction to attach the 1K 2W resistor to either the board or the output tubes. I mean I know where it has to go, but its driving me crazy
Are you positive that it's a 2 watt resistor? They usually include 1k/5 watt cement resistors in most kits for the power tube screens. They are soldered across pins 4 and 6 of each power tube socket with the feed wire connecting to pin 6. I'm not sure where a single 1k/ 2 watt may be needed though.
Some amps use a flying 1k resistor from the turret on the B+ line from the choke to V4 instead of a yellow screens supply. I have it on both my 64 and 65 JTM45s, only brings screen V down a little extra but in these amps sounds spot on.
Gotcha... I really need to build a JTM 45 one day soon. It's the only circuit I haven't tried yet.
Anyone have an active download for this? http://metroamp.com/downloads/JTM_45_KIT_V2.1.pdf
Link is broken.
Link is broken.
Here you go. Valvestorm has a good link at the top of their JTM 45 build checklist page.
http://valvestorm.com/sites/default/fil ... T_V2.1.pdf
http://valvestorm.com/JTM45%20Kit
Hi George,
I have a JTM45 which I wish to install the ZL-FX board I recently purchased. I see links here to instructions (web link and a dropbox link) but both appear to be not working. Can you point me to these instructions ?
Thanks in advance,
Pete DeSisto
Order Confirmation #QG8LFJFJV
Thanks in advance,
Pete DeSisto
