Finished with my 1st ever Build and I feel like a proud dad!
twakeman
Post by twakeman » Fri May 14, 2010 1:14 pm
Hey Everyone,
JTM Kit with SoZo and Mullard upgrades
I am really excited about finishing my 1st electrical build ever. And now I have a Beautiful sounding amp as a result. But it was a rough and humbling experience assembling the amp.
During the assembly and wiring of the amp I ran into a couple of questions that the guy's at Metro awnsered for me. I decied to install a ICE powercord instead of hardwiring it to the amp.
The fun started when I started the testing procedure. During testing my voltage I was get some really high and some really low readings, basically they were all over the place. I retraced all my footsteps and realized that I had my 330uf polarity backwards as well as I forgot the 820 resistor. I fixed the problem and
went back to checking the voltage readings and it was not any better.
So a little frustrated I starting checking everything starting with step 1 and tracing my steps and could not see anything. If it wasn't for the photo of an assembled PT board then I probally would never have seen this. But looking at the 470 resistor that I installed did not look right. So I went to the forum to see if I could find anything and sure enough I found that a lot of newbies like me make the mistake of installing a 470K where a 470 should be. I fixed this and everything else from there was gravy. All reading were correct and I completed the amp.
It was one 0'clock in the morning and I did plug her in with my tele to see what it sounded like and with ther rest of the household asleep I could barely turn it up, so this morning I pluged in for 15 minutes before going to work. Man I sounded good. No hissing or popping in fact it less noice than my mesa boogie. I can't wait to get home tonight and fire her up.
Thank you Metro Amp and everyone on the forum without out you I would have never got her done.
I took pics of the whole process but need to figure out how to post then on this forum. Any help there would be appreciated.
Tommy
Love me some guitar Playing!
95' Les Paul
81' Guild M80
52' RI Tele
Mesa Boogie Transatlantic
MetroAmp JTM45
Marshall 1960
1981 Music Man 12X1 Cabs
Big Mike
Re: Finished with my 1st ever Build and I feel like a proud dad!
Post by Big Mike » Fri May 14, 2010 4:04 pm
Need to host them on photobucket or some such and link using the img code
Looking foreward to seeing it!
Metroamp kit JMP50 - CM OT
Marshall 2550 Jubilee
Scumback Speakers
