New JTM45 build...Voltage Issues
wharris
Post by wharris » Mon Jul 19, 2010 4:06 pm
Just completed my JTM45 build. I checked each connection for continuity as I went along and feel that I have good solder joints throughout (famous last words, I'm sure). I am on the initial first power-up voltage testing stage. On initial tests I have 122V AC from wall. Heater voltages were all 3.5 V AC. I assume that this is in the acceptable range.
V6 was ~5.1V AC between pins 2 & 8
Installed a NOS Mullard GZ34 and Power ON with Standby OFF position.
I am only measuring 148V DC at the Standby terminal and pins 2 & 8
I don't know where to begin to troubleshoot this. I suppose the rectifier tube could be bad, but it came from a very reputable source.
I will try to post relevant pictures.
It's been an amazing experience building this amp using all of the cumulative knowledge found in the hundreds of posts I have read on this great forum. Thanks in advance.
JTM 5.jpg (102.24 KiB) Viewed 2507 times
JTM 4.jpg (98.91 KiB) Viewed 2505 times
JTM 3.jpg (58.88 KiB) Viewed 2504 times
JTM 2.jpg (85.75 KiB) Viewed 2502 times
JTM 8.jpg (91.05 KiB) Viewed 2504 times
JTM 7.jpg (43.1 KiB) Viewed 2504 times
JTM45 1.jpg (91.7 KiB) Viewed 2504 times
Re: New JTM45 build...Voltage Issues
Post by Roe » Mon Jul 19, 2010 5:40 pm
measure AC from PT (to gz34)
wharris
Post by wharris » Mon Jul 19, 2010 6:15 pm
I get 327V AC @ V6 pins 4 & 6
Post by Roe » Tue Jul 20, 2010 3:40 am
wharris wrote:I get 327V AC @ V6 pins 4 & 6
that seems to be right. try a different rectifier (tube)
wharris
Post by wharris » Tue Jul 20, 2010 11:13 am
Thanks. I put in a new rectifier tube and everything checked out. B+ 404V. Biased tubes to 43-45. When I connected to a speaker... loud motorboating with all controls on 0. I lifted the 27k NFB...still loud motorboating with maybe a higher frequency added to the oscillations. I am thinking of adding output grid resistors. I don't plan to reverse the wires to the output grids.
Does this sound right? Any other suggestions?
wharris
Post by wharris » Tue Jul 20, 2010 3:06 pm
I added the output grid resistors and all oscillations are gone. I think I have a new problem.
Input 1 sounds "normal". There is little contribution to its overall volume from "Loudness 1" and a large amount from increasing L 2. The Input 2 is pretty bright sounding, with the opposite effect from the volume knobs as described above. I have triple checked the wiring from board to pots. It is exactly like the picture in the instructions.
wharris
Post by wharris » Wed Jul 21, 2010 12:48 am
I now have a much bigger problem. Decided to retest all voltages. Numbers were all good until I slipped while measuring pin 3 @ V4. There was a spark at V5, no smoke or smell. However, after that: pin 5= -76V (was -42) V4 & 5
pin 3, 4 & 6= 64V DC (was 400, 385, 385)
I measure 347 VAC @V6 #4 and 321 VAC @V6 #6
still 5V across 2 & 8 V6
I also noticed that the VAC on V1-3 went up from 3.29 to ~3.5
Have I trashed my PT? Feeling quite dejected at this time...
Post by Roe » Wed Jul 21, 2010 3:33 am
PT is good. check rectifier tube, fuse and bias circuit
wharris
Post by wharris » Wed Jul 21, 2010 11:23 am
Thanks Roe. My 500mA fuse was blown. I am an electronic imbecile , but I am learning daily thanks to nice people like you. I appreciate you taking me under your wing on this.
My problem now is that Input 1 sounds normal (warm), Input 2 is bright. Volume 1 doesn't contribute much to Input 1 level, but Volume 2 does. In other words, If plugged into top left (High 1) Volume 1 (which sounds bright) adds minimally to overall volume, but Volume 2 (which sounds much warmer) adds most of the volume level. The opposite occurs when plugged into top right. I know that I am wired correctly according to George's instructions/pictures, but I also note that on his cartoon picture indicating the wiring of the pots, he calls the most leftward volume pot (when looking down on chassis-circuit board up-) Volume 1, when really it is Volume 2. I am not jumping inputs.
Is this the normal way that these controls should interact? My Super Lead doesn't behave in this way (Vol 2 has very little effect when plugged in to top left Input 1, and so on).
wharris
Post by wharris » Sun Jul 25, 2010 5:06 pm
Has anyone else had a problem with the inputs being essentially reversed? I am sure that I wired the amp just as directed.
mwm523
Post by mwm523 » Sun Jul 25, 2010 6:09 pm
wharris wrote:Has anyone else had a problem with the inputs being essentially reversed? I am sure that I wired the amp just as directed.
Trace your input and volume pot wires. I know you say that everything is wired correctly, but it sounds like you reversed something somewhere.
Take a look at the below, it's from the 50W kit instructions, but the inputs and volume pots are wired the same way as the JTM45:
Make sure that when looking down at the board as in the pic, that:
1. the left input green wires (input II) go to the left set of 68K input resistors.
2.the right input green wires (input I) go to the right set of 68K input resistors.
3. the left volume pot (volume II) wires go to the first (leftmost) .022uf coupling capacitor and the first (leftmost) 270K (470K in the pic) mixer resistor.
4. the right volume pot (volume I) wires go to the second .022uf coupling capacitor and the second (rightmost) 270K mixer resistor.
-Mike
wharris
Post by wharris » Sun Jul 25, 2010 7:29 pm
Thanks Mike. My wires go exactly as your diagram shows. The odd thing is that if you look at that same growing from the JTM45 instructions, vol 1 and vol 2 are (from L to R) labeled 1,2 even though that is not the way the pots are mounted. I assumed that the drawing was mislabeled, but that the leftmost wire would go to the first pot and so on. Looking at the photos in the directions seemed to reinforce this, but maybe I should just swap Vol 1 & 2 wires. I remain confused...
mwm523
Post by mwm523 » Sun Jul 25, 2010 9:35 pm
Can you post some good clear pics of that area, as well as the wires going from the other side of the board to V1?
-Mike
wharris
Post by wharris » Sun Jul 25, 2010 10:49 pm
Mike, your request for V1 pictures got me thinking. I checked my board and the green wires to pins 2 and 7 were reversed. :oops: After a quick re-wire of those two everything is perfect. It sounds great, and is quiet as a mouse (Star/Larry)! And best of all, I built it with my own two grubby hands (and a lot of brain power from nice people like you). I feel fortunate to have scored one of these great kits just before the store closed down. I hope that George is able to get it up and running in the near future. Thanks for your help.
mwm523
Post by mwm523 » Mon Jul 26, 2010 4:30 pm
Cool, glad to hear you got it sorted out. Congrats!
-Mike
