Attenuators?
Attenuators?
Is anyone using any sort of power attenuator on their JTMs here? If so what are you using and what kind of results are you getting? Thanks!
RickS
- rjgtr
I'm using a Weber MASS or THD Hotplate (I own both). I like the feel of the Mass more; the THD makes the amp a little stiffer. Both keep the basic amp tone as long as you stay in the upper 3rd of the attenuation, then the tone changes a little with both.
Richard Johnson
