intermittent Hiss/Hum Help???
TheOuvs
Post by TheOuvs » Wed Oct 27, 2010 8:23 am
Does anyone know what would cause my new build to have a hum/hiss that seems to build up then fades away? All the tone is still there, there is just this build up off a hum. If I turn the stand by switch off it goes away for awhile. Again, the hum is very iintermittent and fades in and out.
billstets
Re: intermittent Hiss/Hum Help???
Post by billstets » Wed Oct 27, 2010 1:32 pm
I'm no expert, but have tried swapping tubes. That always seems to be the first thing to try. If it's not a tube, I'd say a bad solder joint. But there are much more knowledgeable people than me here.
TheOuvs
Post by TheOuvs » Thu Oct 28, 2010 9:51 am
Thanks Bill,
I have checks the solder joints and a couple were suspect, re-flowed them and am now testing. We'll know soon.
Thanks,
Kris
billstets
Post by billstets » Fri Oct 29, 2010 8:05 pm
what about the tubes?
TheOuvs
Post by TheOuvs » Fri Oct 29, 2010 9:29 pm
Tested for about 4 hours yesterday and the hum / hiss seems to be gone. Could have been a solder joint or a wire that extended a little too far past the solder joint (did some trimming). Thanks for your help.
