Need Help Troubleshooting
Posted: Tue Nov 16, 2010 11:10 pm
I'm building my first amp (JTM45). I sourced the parts from a builder and the transformers are ******. I've been following the Metroamp build instructions and I just finished the amp today.
The voltage measurement were all pretty close to those in the instructions, but when I installed the power tubes and tried to bias, the V5 tube was much lower (about 15-20mA) than V4. I know that they tubes matched much close, but for the hell of it I tried two other pairs and got the same thing.
Up to that point I was biasing according to the instructions so I figured I try my Amp Head bias probe. Same thing. With these I could measure the plate voltage and V4's was .437vdc while V5's was .022vdc.
Like I said, this is my first build. What should I check first?
