push pull pot
push pull pot
I'm currently running my JTM45 as what I believe to be bass spec, no cap on the volume pot. I was thinking it might be cool to put a cap on a push\pull volume pot, so that I can have lead sepc if I pull it out. Does anyone know of a pot that might work for this application?
Re: push pull pot
hey thanks a lot. Do you know if the Marshall type knobs will fit on that shaft?
- arledgsc
Re: push pull pot
The push pull knob shaft appears to be the same diameter (1/4") as say the Alpha pots. It will require enlarging a new knob slightly with a drill bit (not powered but by hand). I found it easiest to start the enlarging process with a 15/64" bit and then finish with 1/4". Take a look at the link below for more information. Maybe your old knob is already sized and then in this case it should just slip right on. Scottbillstets wrote:Do you know if the Marshall type knobs will fit on that shaft?
http://forum.metroamp.com/viewtopic.php?f=15&t=32217
Metro JTM45, Metro 50W Lead, JTM50 Black Flag, and Ceriatone 18W TMB
Scumback M55/M75, Ceriatone C-lator
