I finished up my first build, a JTM45, and it powered up and KT66’s biased at 39mA . I started playing and it sounded pretty good at low volume, I cranked the volume and the amp just doesn't shake the walls...I could easily turn it up to 5 or 6 and the amp is not loud at all and not much bass...something definitely wrong
I put it back on the bench and took measurements. Voltages seem good on the tubes, I can't remember exact readings but I can update the post later, I'm getting about 480v plate and bias is -52v. The weird thing is, with no input, if I turn up the bright channel volume the voltage on V4 pin3 drops considerably. I checked the same measurement on V5 pin 3 but the voltage stays around 470. If I turn up the normal channel with no input I don't get any volume drops. I replaced all the tubes (including preamp) checked component values (and yes, it's a 470 to the PI not 470k
Since I’m getting a voltage drop on one side of the primary OT with no input, does this suggest a blown primary winding? I thought I had some weird oscillation that is causing the voltage drop but if that was the case, shouldn't I get the same reading on V5?
I was reading the geofex on simple OT testing and I'm starting to think it's an OT issue because I measured the resistance from all the pins to the chassis and I got a very low reading. I also measured the primary resistance of the OT as it sits in the amp and on one primary to CT I'm getting 120ohms (the side that gets the voltage drop) and 80 ohms on the other side to CT.
I thought I would hit up the forums for any other suggestions since I'm new to amp building and need to bounce some ideas off people. Thanks for the help and sorry for the long post!
