Hy to all,
Was wondering if any of you could tell me if this diagram contains possibillity's or not.
It is all about V1, the first half of the relais does the channel 1 + 2 switching ( note: both channels at the same time ) the other half of the relais i 'd like to use for cathode-settings when both channels in use..
Point is the cathode values, must be right this way i think...
Relais switchable channels JTM
- Giablo
- channel switch1.jpg (20.21 KiB) Viewed 1460 times
make your own point.... to point.
Re: Relais switchable channels JTM
Hello giablo,if you make the 820ohm resistor also 1k6 then you prevent popping noise.
When you switch then parallel you have 820 ohm with 0,68uF.
Groeten
Erik
Ps.leave the 1k6 resistor connected to the kathode.only switch the resistor/capacitor combi
Groeten
Erik
