Where to ground PT Faraday Screen using the "Larry" method
Posted: Wed Oct 16, 2013 9:34 pm
by Matt D
I am assembling a JTM 45 using I.G. Prazisions Wickeltechnik transformers from Ingo Gorges. His mains transformers have a ground lead for faraday screen. Where should this lead be grounded using the Larry scheme? Thanks!
Re: Where to ground PT Faraday Screen using the "Larry" meth
Posted: Thu Oct 17, 2013 8:53 pm
by EFK
I don't know where Larry would ground it, but those are generally grounded right to the lone AC ground. As far as I know, this is the only exception to the "AC ground isolated on its own bolt" rule. I have always grounded them there, when using PT which have this shield brought out to a separate lead, and have never had any problem or adverse noise artifacts.
Posted: Fri Oct 18, 2013 8:03 am
by HTH
Have you asked Ingo? - would be worth dropping him an email.
Sweet iron btw, Ingo makes NICE stuff.
Posted: Mon Oct 21, 2013 2:57 pm
by Roe
I'd try to ground it together with the mains filter cap. but you could always experiment, listening for noise
