Will different choke value change plate voltage?
jbzoso2002
Post by jbzoso2002 » Fri May 25, 2018 7:28 pm
Say a 4h vs a 10 or 20 h???
Just curious.
Thanks Jimmy 8)
Re: Will different choke value change plate voltage?
Post by neikeel » Sun May 27, 2018 5:16 am
Not if you mean outputs.
OT HT feed (centre tap) on a Marshall is before the choke so at idle no
Of course when the amp is driven and lots of current being drawn the behaviour changes.
What you do not ask is the DCR of each choke and its current handling capacity..........
JimiJames
Post by JimiJames » Mon May 28, 2018 8:19 am
Will change the feel of the amp. Choose wisely.
Build'sClip'sVid's
Post by Roe » Mon May 28, 2018 2:31 pm
The DCR of the choke will affect the screen voltage and indirectly also the plate voltage. Higher resistance will decrease screen current and plate current, leading to higher plate voltages
jbzoso2002
Post by jbzoso2002 » Tue May 29, 2018 11:05 pm
Thanks for your answers, from what I gather a 4h would
nudge the plate voltage lower rather than higher???
Thats whats in it and I have 467.
Higher than i wanted. Its a classic tone pt.
Jimmy
Post by Roe » Fri Jun 01, 2018 11:46 am
it depends on the resistance not the henries
Post by neikeel » Fri Jun 01, 2018 4:36 pm
Yes - see my post above :wink:
