Got some descent voltages compared to the chart, a little below the chart on most of the readings because i used the 240v tap, and i've measured 230v in my socket, so thats not unusual. Without the power tubes i had about 420v on pins 3,4 and 6. And around -42v on pin 5.
So I poped the tubes in, and hooked up my multimeter.
I had my Hot plate set on load, and i also used the line out and ran it into my computer, so that I could hear any wierd noises if something was wrong..
When i hit the standby switch, i got a pretty wierd oscillating noise, and about 140mV on pin 8
How could that happend.. little confused about the matching of the tubes also, the boxes says, 3.6 / 3.3 but the notes inside the box says on one tube 80ma
and the other 50ma..
