Resistor question - power rating
Posted: Sun Mar 05, 2006 10:37 am
by shakti
In my JTM45 kit, there is no 10k metal oxide resistor. There is, however, a carbon film 10k resistor. Is this one fine to use in the slot right next to the on-board 16uF capacitor? I think the metal oxide ones are rated at 2W and the carbon films at 1 watt (although this 10k carbon film is physically larger than the other carbon films in the kit...).
In most photos I see here, and in George's kit photo, that slot has a metal oxide, that's why I'm asking.
On a related note, why does the kit ship with metal oxide resistors for the 820 ohm V2 cathode resistor and the 100k right next to it? Any reason for metal oxide there, and not standard carbon film?
Posted: Sun Mar 05, 2006 11:11 am
by shakti
And to follow this up...I asked for carbon comps for the typical positions (inputs, mixer, cathodes, tone stack and feedback), but see now that I got CCs for most positions. Are there any spots where I should avoid CCs to reduce noise?
Posted: Sun Mar 05, 2006 12:44 pm
by shakti
Even more specifically, I'm worried about the following resistors:
- 220k bias splitter resistors - are CCs OK there?
- What about the 220k in line with the diode on the board?
- And what about the 470 ohm which is between the two 1MOhm resistors (I'm not sure what this resistor is)?
- The 10k which connects to the common point of those three resistors mentioned above (2x1M+470)?
- 82k and 100k between the PI caps?
- 15k between the bias caps?
If anyone can tell me if CCs will be fine in all these positions or if I should avoid them somewhere, I'd be most thankful!
Posted: Sun Mar 05, 2006 1:33 pm
by Flames1950
Carbon comps are working fine in all those spots in my build........
Posted: Sun Mar 05, 2006 2:07 pm
by shakti
Thanks!
I see that the Germino amps seem to have CCs pretty much in all positions. But that means I must get some 1M CCs to keep the look "complete"... :roll:
Posted: Sun Mar 05, 2006 3:22 pm
by VelvetGeorge
I had to sub in a 10K 2 watt carbon film because I was out of the MO's. I can send you one if you like, but the 2 watt CF is well within spec.
Just let me know.
