SO does it have the TONE
topsportsmanta1
Post by topsportsmanta1 » Sun Nov 29, 2015 8:11 pm
! see post under general evh
Last edited by topsportsmanta1 on Tue Dec 01, 2015 5:44 pm, edited 2 times in total.
mike
efraser68
Re: SO does it have the TONE
Post by efraser68 » Mon Nov 30, 2015 9:52 am
What era are you aiming for? Too much preamp gain for early Roth era. It sounds like an EVH 5150 iii series or maybe the new MXR pedal :what: Tell us what the amp is and what you want to achieve and more folks will chime in.
topsportsmanta1
Post by topsportsmanta1 » Mon Nov 30, 2015 10:27 am
Thanks eric for taking a listen
its first time ever trying to record this amp it is a rockstah mod 6 that mark had come up with , retains the same tone no matter were the volume is , it sounds like sean mcflys in person but recording it it changes bad , I think maybe it was mic placement , n what I am using that im loosing the tone , I am going sm57 into pa system out to a behinger sca202 then into computer thru junkie audacity any help would be much appreciated here is the hardware n settings I used
(371.06 KiB) Not downloaded yet
(35.22 KiB) Downloaded 456 times
(53.69 KiB) Downloaded 456 times
mike
topsportsmanta1
Post by topsportsmanta1 » Mon Nov 30, 2015 10:49 am
Settings
(388.23 KiB) Not downloaded yet
mike
Strat78
Post by Strat78 » Tue Dec 01, 2015 1:55 pm
If by "tone" you mean Glenn Tipton's, then yes. :rock:
What's up with that MM tranny using Marks moniker? What is the story behind that! :shock:
topsportsmanta1
Post by topsportsmanta1 » Tue Dec 01, 2015 5:28 pm
moved to general evh
mike
