you know,i dont think i payed attention to which way north was.i wonder how i could find that out now,lolrockstah wrote:just loosen the 4 screws on the under side of the pickup. u don't need to take them all the way out. pay attention to which direction the magnet is inside and then slide the new one in. most magnets will have a "N" indicating north. put the new magnet with then N facing the same direction. its really easy actually.
dimarzio super distortion with a alnico 5 magnet-WOW!!!!!!
My EVH sound clips.
My EVH sound clips.
- rockstah
the only difference it will make is if you are running two pickups at once. phase issues can be created or resolved by flipping the magnet around.bmf5150 wrote:you know,i dont think i payed attention to which way north was.i wonder how i could find that out now,lolrockstah wrote:just loosen the 4 screws on the under side of the pickup. u don't need to take them all the way out. pay attention to which direction the magnet is inside and then slide the new one in. most magnets will have a "N" indicating north. put the new magnet with then N facing the same direction. its really easy actually.
you know how magnets draw to each other or push away form each other? take a pickup that hasn't been messed with and a magnet that you know which way is north and push it to the pickup u will be able to tell by the pull or push now make your pickup act the same way.
- fillmore nyc
cool,i didnt know that..im only using one pickup..rockstah wrote:the only difference it will make is if you are running two pickups at once. phase issues can be created or resolved by flipping the magnet around.bmf5150 wrote:you know,i dont think i payed attention to which way north was.i wonder how i could find that out now,lolrockstah wrote:just loosen the 4 screws on the under side of the pickup. u don't need to take them all the way out. pay attention to which direction the magnet is inside and then slide the new one in. most magnets will have a "N" indicating north. put the new magnet with then N facing the same direction. its really easy actually.
My EVH sound clips.
My EVH sound clips.
mine too!!!!gnugear wrote:My Super Distortion is definitely glued in.
My EVH sound clips.
My EVH sound clips.
- LypsLynch55
Try a heat gun on it (with the bobbins OFF of course). Keep the wire from getting to hot by taping it down on something or try not to hit it with the gun too much. If its waxed in there, this should take it out. If its glued in there, it may help a little (depending on the glue used). I think if you hit it with the gun, the glue should loosen a little to be able to pry it out.gnugear wrote:My Super Distortion is definitely glued in.
If that doesnt work, just put the coils/bobbins on another baseplate w/A5 magnet - like if you have a '59 or a Custom 5 or something like that sitting around. Or you could order some parts from Stew Mac or High Order. WCR sells magnets, but they are custom cut to fit WCR pickups, so they wont necessarily work on anything else.
Hope that helps.
"Just shine the echo there....Tommy get those cords that we use" - DLR during the Pasadena Rehearsal
a screw driver will pry it off..
My EVH sound clips.
My EVH sound clips.
So how does it sound ? clips ? I have one too but never liked it....
http://www.sozocapacitors.com" onclick="window.open(this.href);return false;
change the magnet...SoZo wrote:So how does it sound ? clips ? I have one too but never liked it....
My EVH sound clips.
My EVH sound clips.
I did.... back in 87, It was ok but I liked my real PAF better
