REFERENCES FOR RALLE's VH/AMP/SPECS/GEAR/SET-UP, etc.....
- 5150loveeddie
Don't forget Ralle uses a JB pick up, that is really not the same as what Eddy used........Ralle adapted and fine tune his amp to make it sound like VH..........JJtubes? Not Sylviana, etc....etc....so those little details got adjusted by increasing/decreasing capacitance among other things etc...etc....Ralle has great hears to do that...........
- mightymike
It's almost as if Ralle was experimenting with the Values in ******'s description of EVH's amp, but had to add the .68uf to the presence to make up for the reissues. The end goal tone being the same, just 2 different paths to get there. So if you have RI Greenbacks try Ralle spec, but if you have the real deal 12h30 Pre Rola or Heritage go with Cerrems 1.1k rks too will add to your gain.
- 5150loveeddie
Yep!!!!!!!!
- rockstah
- Flames1950
Hmm, my ears told me the opposite, that the 820 had a warmer sound, since the bypass cap was not as effective with the lower value resistor, despite the higher frequency shelf of the cap/resistor combo. The bigger the cathode resistor, the more the signal would rather go through the cap if it can, so your bypass cap's gain boost is more apparent........another of those balancing act things we run up against.
- rockstah
i beg to differ!Flames1950 wrote:Hmm, my ears told me the opposite, that the 820 had a warmer sound, since the bypass cap was not as effective with the lower value resistor, despite the higher frequency shelf of the cap/resistor combo. The bigger the cathode resistor, the more the signal would rather go through the cap if it can, so your bypass cap's gain boost is more apparent........another of those balancing act things we run up against.
changing v1b from 820 to 2.7k
- 820 will have more distortion in the higher freqs- thinner overall
2.7 will be thicker -not as much distortion - alitte warmer / fatter sounding
Mark
- 5150loveeddie
Hey Mark your only rebiasing your pre amp tube with different resistor value there, from 820ohms to 1.1k you'll get a smoother result....try it and less us know.........
- rockstah
i plan on trying the 1.1k very soon5150loveeddie wrote:Hey Mark your only rebiasing your pre amp tube with different resistor value there, from 820ohms to 1.1k you'll get a smoother result....try it and less us know.........
i also want to experiemnt with 820 on v1b and .022 and then 2.7k on v1b with .0022
- rockstah
- mightymike
I used some 1.1ks and like this setuprockstah wrote:i plan on trying the 1.1k very soon5150loveeddie wrote:Hey Mark your only rebiasing your pre amp tube with different resistor value there, from 820ohms to 1.1k you'll get a smoother result....try it and less us know.........with my findings as of lately i even wonder what it would sound like with 1.1k on v1b and a 2.7k on v2a.
V1----> 330uf/1.1k, .68uf/2.7k
V2------>330uf/1.1k
.02 after the first Stage
Slope /Treb 56k/250
Mixer 470k/500pf
I'd like to try some 1k, or 1.1k cement resisters in those spots.
[/quote]
- Bainzy
http://www.metroamp.com/forum/viewtopic.php?t=6385
Here's my observations of the resistor - I think this is way more important than any of the above components you guys mentioned (ie. filtering, cathode resistors).
Shred Guitar
Shred Guitar
- 45auto
is it rediculous to put variable resistors in positions on the preamp tubes for fine adjustment? i used to do that back in the late 70's.
