VH Clip w 2 Variacs
Re: VH Clip w 2 Variacs
Sounds fantastic Rob!!
Which pup was that? DSD? Which value is the bright cap at the vol pot and how is your NFB set? Man, one of the best tones I've heard .. it has all the warmth, chewyness and that smack in the solo notes that I love and can't seem to get in my amp
Also, which tubes??
Keep coming the clips man,
Also, which tubes??
93' Fernandes SSS strat
93' Fender Japan HSS Strat
Nice
What was the speaker variac down to on the dial? what were your thoughts to the feel/tone using the second variac.
- rgalpin
my mistake - i think it's .0022 on V1b. CH I. High and tight!jnew wrote:What the hay? I posted earlier but now I don't see it.
Are both V1 couplers .022's? Hard to tell from the pic.
- rgalpin
Thanks man! PUP is from the Fender/EVH B&W Stripe...fhn_lopes wrote:Sounds fantastic Rob!!
Also, which tubes??
Bright cap on vol pot: It looks like it's removed. Don't know why though - i usually enjoy a 5600pf
NFB wired to 8 ohm i think. NFB resistor 27K i think.
EH 6Ca7s
- rgalpin
The speaker variac is a curious thing. Part of it depends on how you hook it up: AMP SPKR OUT connected to VARIAC MALE which what I would call normal. Or backward... AMP SPKR OUT to the female.jape88 wrote:Nice
It seems to sound best when you hook it up backwards. But when you hook it up that way, it's a little less clear what is happening to the tone in relation to the setting. Hooked up forwards it seems to track linearly where lower voltage settings are thinner and quieter. Backwards though it's a little less like a linear reaction. I had it set at about 60V in the clip. The AMP variac was at about 60V too.
It feels really really good in the room. Browned out but yet at the same time boiling over.
Hell of a thing, isn't it. I think I would argue that this is better than sliced bread. In fact, I'm gonna call my variacs bread and butter from now on.
- Tone Slinger
Rob, man after hearing your tone here, I had to put a hat on so I could take it off for you
Amazing browness and playing articulation !
- vanhalen5150
Sliced bread? Maybe a toaster as a load next?
Good tone Rob.
Nice to see people still trying new ideas out.
Good tone Rob.
- rgalpin
Thanks guys! Here is Somebody Get Me a Doctor:
http://www.robgalpin.com/wp-content/upl ... GMAD-2.mp3
- vanhalen5150
whereas the tone is naild for VHI, I think this one sounded a bit off compared to the original. I beleave it's the pickup?? I can hear my BKP VHII doing SGMAD spot on but not VHI... the VHII album sounds darker and more mid focused IMO, but anyways this tone you're getiing is in my top 5 Rob, congratulations. Makes me want to buy two variacs so bad I need to raise some $$ fast. also need a DSD or Sh5, still in doubt between which one...rgalpin wrote:Thanks guys! Here is Somebody Get Me a Doctor:
Interesting how small things affect the tone in a drastic way. I suggest you to record SGMAD again with a frowny curve at the 6band instead of a smiley one... maybe it can get you there.
- rgalpin
yes - there is the difference between vhi and vhii so can't be getting both tones with the exact same setup. i think there is a core piece in the way this setup grinds. maybe this is a common element across all the early albums.
here is a W&CF clip for comparison:
http://www.robgalpin.com/wp-content/upl ... TYWH-2.mp3
the volume in the room - it's not very loud at all - like not even close to the volume of a snare drum. when i get some time i am going to make some clips at snare drum volume to see what that adds. i am assuming it will add some more knock and backbone - which is one element that is a little weak in this setup at low volume -
