jnew wrote:EVH had no NFB, is what I think you meant. Hmm, I can't say this would be completely out of the question. I may have to revisit that. Definitely had something "HOT" about it, for lack of better words.
yes, no NFB. I figured you guys knew what I meant.
Anyway, after reading my post again... what I said doesn't make sense. My impedance selector is fine. No matter where I place the purple NFB wire, the sound does not change.
First I installed a Lar/Mar style PPIMV (250k) and everything was fine. Then I started experimenting with bypass caps on V2 and everything seemed fine. Then I installed a resonance pot (1meg with .0047uf, NFB is 47k on 8ohm tap) and then I noticed I was getting breakup no matter where my volumes were, AC/DC overdrive as low as 2 and full 'metal' on 10. I removed the resonance pot and put it back to 47k/8ohm but the sound didn't change. Presence control did nothing. It's obviously something simple but since I'm using the original PCB, I'm annoyed
Oh well, that's part of the fun right?
mightymike wrote:A 27k NFB in Series with 1M Pot would cover a lot of range
Yeah that's what I plan on using... eventually. Good call
