I did these and thought just pulling R28 sounded best. Then I went and lost one of the caps.Ruben wrote:I've done this also: clipped R28 & C11 & C12. Nice sound, but not good enough for me. I liked the EVH in script mode better and now building an Script Phase 90 (with original board & components)
How to adjust a Script Phase 90 out of the mud sweep?
i have moved my trim pot before and i donot know wher the stock setting is? any sugestions on how i can reset it?? Its a newer orange reissue. Again i did the r28 c 11 c 12 mod!
69 SuperBass Plexi
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
2550 Silver Jub stack
71 LesPaul Deluxe
68,71,73 4x12
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
71 LesPaul Deluxe
68,71,73 4x12
I did a Build Your Own Clone phase 90 and love it! I built one when the first kit came out and it was a lot better than a new MXR with R28 mod. Since then I heard they updated the kit so I built another one and it's even better. I remember that the sound was different when turning the trimpot clockwise vs. counter clockwise. Can't remember which direction I decided on but I dialed out the low end flub and the effect is much more subtle, which I'm guessing is more like an original one. I used to not use it much but now I can leave it on without the effect overpowering to sound.
Gear:
'73 Super Lead
'70 Basketweave
'73 Super Lead
'70 Basketweave
i got the build your own clone phase 90 after talking to gnugear about it..i love it,way better than the reis and doesnt rob your tone plugged into the pedal.gnugear wrote:I did a Build Your Own Clone phase 90 and love it! I built one when the first kit came out and it was a lot better than a new MXR with R28 mod. Since then I heard they updated the kit so I built another one and it's even better. I remember that the sound was different when turning the trimpot clockwise vs. counter clockwise. Can't remember which direction I decided on but I dialed out the low end flub and the effect is much more subtle, which I'm guessing is more like an original one. I used to not use it much but now I can leave it on without the effect overpowering to sound.
My EVH sound clips.
My EVH sound clips.
Re: How to adjust a Script Phase 90 out of the mud sweep?
I have a phase 90 block print that had the diode replaced from incorrect polarity, The light comes on when the button is pushed but no sweeping? It sweeps only when I turn the tweaker pot. And when button is pushed there is a noticeable boost in volume. Any suggestions?
Thanks.
Thanks.
Not sure if this posted already? I have a block print phase 90 that has replaced the diode from incorrect polarity. Now when the button is pushed, the light comes on, it gives a slight boost, & no sweep. It only sweeps with the tweaker but auto. turmimg the tweaker I get a slight sweep ?? Any ideas?
Thanks.
Thanks.
