How to adjust a Script Phase 90 out of the mud sweep?
I know we've talked about how ED's phaser never really dropped into the lower frequencies of it's sweep making it kind of a treble phase boost effect.
I have an original script phase 90 has a trimpot inside it.
Which direction counterclockwise or clockwise adjustment would adjust it to where it would not sweep into the mud?
How much does those little trimpots rotate I don't want to break it?
i would mark the stock setting before you play with it so you can go back to it if you need to..
My EVH sound clips.
My EVH sound clips.
+1 !!!!bmf5150 wrote:i would mark the stock setting before you play with it so you can go back to it if you need to..
Don't forget to do so
MY WEBSITE: http://www.rubenhoeke.com
FACEBOOK: http://www.facebook.com/profile.php?id= ... ef=tn_tnmn
i actually took my new reissue phase 90 and did the r28 mod and i also pulled 2 other componentes out. Has anybody else done this?? Seems to get rid of the boost(mid)?? and make it somewhat like a older script?"?
69 SuperBass Plexi
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
2550 Silver Jub stack
71 LesPaul Deluxe
68,71,73 4x12
12000 Series Bulid
73 1987
68 Nos 50 build
2554 Combo
71 LesPaul Deluxe
68,71,73 4x12
I've done this also: clipped R28 & C11 & C12. Nice sound, but not good enough for me. I liked the EVH in script mode better and now building an Script Phase 90 (with original board & components)
- Strat78
Both my script phase 45 and 90 trem pots were soldered into position (annoying). I've sense un-soldered them and adjusted the pots accordingly,however I was surprised that the sweet spot was in the space of a fraction of an inch. Turning the pot to the left or right of that spot for the most part did nothing. Is this normal?
Kewl, can you link me to where you are getting the kit or parts?
Ruben wrote:I've done this also: clipped R28 & C11 & C12. Nice sound, but not good enough for me. I liked the EVH in script mode better and now building an Script Phase 90 (with original board & components)
http://www.sozocapacitors.com" onclick="window.open(this.href);return false;
Sorry for the confusion, I just bought a Phase 90 script board at my local pawn shop, cost me 5 dollars. Now a friend of mine built me a MXR 'copy' box and soldered the jacks, power etc. It's just a Script Phase 90 in a self made box with new jacks....Best phaser sound I've heard so far.
I've had stock block logo's / modded block logo's / EVH and 1 Script logo but messed with...this one is by far the best...beautiful lush, warm etc.
As several have pointed out, be sure you mark the original position down to a gnats ass!!!!!!! Any type of adjustment should be veeeerrrry subtle. I fiddled with one a few years ago and never got it back in the original position (which was actually the optimal position). The pot acts more as a balance of the phase sweep. If you have it set too far left/right of that optimal position, then you'll have a unbalanced lop-sided phase sweep. All the way left/right and you have no phase.
- T.J.Fuller
I've done the r28 and removed c11 not c12 on a re-issue block logobeaulieu wrote:i actually took my new reissue phase 90 and did the r28 mod and i also pulled 2 other componentes out. Has anybody else done this?? Seems to get rid of the boost(mid)?? and make it somewhat like a older script?"?
and just like Rueben mentioned, it's better ..but not the same as the older script Phase 90's.
I'm happy with mine this way but, a/b'd against a VH clip...it's still different sounding than VH.
better sweep than the EVH striped phase pedal for sure...more musical
I know we talked about this months ago but, has anyone noticed the
Dunlop custom shops NEW 2nd. re-issue of the 70's script phase 90???
The inside looks pretty close to an Original script...of course..that never means a whole lot until you test one out or buy one
2nd. re-issue? you mean the SCRIPT PHASE 90 CSP-101SL (WITH additional LED) ???? That pedal supposes to use the exact same circuit as the EVH Phase in script mode....
- T.J.Fuller
This 2nd. one is called the 1974 re-issue script Phase 90 , so it is another NEW MXR Phase 90 model and it is 119.00 versus 159.99Ruben wrote:2nd. re-issue? you mean the SCRIPT PHASE 90 CSP-101SL (WITH additional LED) ???? That pedal supposes to use the exact same circuit as the EVH Phase in script mode....
here is a link- http://www.musictoyz.com/guitar/pedals/mxr.php
maybe this is Dunlop's way of covering up the huge mistake they made on the CSP-101SL ala EVH Phase in a different box .
I'm very curious about this new one
mmm....strange indeed....
I thought they said the CSP-101SL supposed to have THE classic script sound? Jeez, how many Phasers do they have?
*Block
*EVH
*CSP-101
*2nd re-issue
Wonder if they get it right this time...anyone gonna check it out?
Now that I have a original script I don't need to try it...well maybe buy the housing
*Block
*EVH
*CSP-101
*2nd re-issue
