Thanks for the compliments RGalpin! and Extra Special Thanks to ROCKSTAH for helping me make a Killer sounding amp!rgalpin wrote:wow! those sound so solid man - with that blooming spank. awesome.vkaxeman wrote:I don't usually post my Marshall 1959HW amp mp3's in the Eddie Van Halen section but I did make me one of those Rockstah Line Out Boxes per Mark's diagram/spec and slaved my Marshall 1959HW that Rockstah helped me tweak to be dutch with a Marshall SLP Reissue. Sounds pretty FN good slaved and definetly leans toward the early EVH sound. At least to me anyway. So I thought I would share them.
can you please share some of the details of the spec on the amps?
can you give the run down on this?...my Marshall 1959HW that Rockstah helped me tweak to be dutch ...
v1b cathode?
v1b coupler?
mixer?
v2a cathode?
tone stack?
fizz cap?
output couplers?
thanks man! more questions to come... but this would be a great starting point. much appreciated.
The Marshall 1959HW Rockstah Tweaks Amp current specs are:
v1a 330/820
v1b .68/820
v1a coupling .022
v1b coupling .022
vol1 bright 500p
tone stack 250p/56k
v2a .68/820
tone stack capacitors both .022
Phase Inverter Input capacitor .022
Output Coupling capacitors both .1
Screens 16u
Mains 32u
V3 PI 16u
Preamp 32u
Presence .1
220k resistor on V2 Pin 2
Mercury 7h Choke
Chinese 12AX7A Pre Tubes
JJ EL34 Power Tubes
Lar/Mar PPIMV
Georges Dagnall Clone OT
Georges Dual Tap PT on Low Voltage Tap
The full detailed history of me modding this amp with Rockstah's wisdom and guidance is here:
http://forum.metroamp.com/viewtopic.php?t=11549
The Marshall SLP reissue is 100% stock non-modified amp.
One of these.
http://www.marshallamps.com/product.asp ... de=1959SLP
I am using the PowerBrake and LineOut box just like Rockstah's setup. From the lineout to the Return in on the effects loop on the SLP to bypass the preamp section of the SLP. JCM800 1960a Cabinet with G12M-25 watt-75hz-16 ohm Greenbacks with 6402 cones.
