Mighty Mite 1400 vs Dimarzio Super II
Ralle
Post by Ralle » Sun Dec 18, 2011 5:30 pm
Ok... since most of you guys know by now that I want that MM pu... and they seem pretty hard to get...
Can I get some reviews and comparison between the two pu's?
Thanx in advance :wink:
Marshall SL12301
Re: Mighty Mite 1400 vs Dimarzio Super II
Post by Marshall SL12301 » Wed Dec 21, 2011 2:13 pm
$35 finds out? :mrgreen:
heres one over at TGP
http://www.thegearpage.net/board/showth ... p?t=989460" onclick="window.open(this.href);return false;
Strat78
Post by Strat78 » Thu Dec 22, 2011 4:59 pm
Marshall SL12301
Post by Marshall SL12301 » Thu Dec 22, 2011 8:11 pm
dont know about everyone else but listening to strat 78's LD riff on that clip with a MM1400 vintage i hear something in the tone that the MM1300 just doesnt have, nor does the super d have it? something in the mids is right with the 1400
Strat78
Post by Strat78 » Thu Dec 22, 2011 9:20 pm
Marshall SL12301
Post by Marshall SL12301 » Thu Dec 22, 2011 9:25 pm
Strat78 wrote:I like the 1970's 13.8k MM the best, this was a little too close to the strings, so it got a little overdriven, but it had lots of snarle and feel. Sorry guys for draging out this old clip agian, but it seems relevent to the conversation.
http://soundclick.com/share.cfm?id=8101401" onclick="window.open(this.href);return false;
All my recent tone test clips are with a old DSD.
Is that the stock MM1300 or a alnico 8 modded one?
I am after a MM 1400 if you are selling one?
rgorke
Post by rgorke » Thu Dec 22, 2011 9:29 pm
Mr Strat sir, what are the specs on the amp? Is that yours? Or Ben"s?
Marshall SL12301
Post by Marshall SL12301 » Wed Dec 28, 2011 1:08 pm
I dont own a 1400 to compare but would also really like to know if these super 2's can be a sub like the DSD was for theMM 1300
Ralle
Post by Ralle » Wed Dec 28, 2011 10:10 pm
I know the magnets aren't the same in Dimarzios and MM's... both the 1400 and 1300 are way bigger than the Dimarzios...
The D 2 messaurers about 8.7k...as the 1400 8.6... so if there's a magnet swap, it would be the same, right
Marshall SL12301
Post by Marshall SL12301 » Thu Dec 29, 2011 6:00 am
Magnets can vary strengths depending on their charge for instance dimarzio may have used a smaller mag but it had a strength(gauss) the same as the MM larger magnet.
Ralle
Post by Ralle » Thu Dec 29, 2011 9:46 am
Hmm... another thing to add to my knoledge base... :wink:
mightymike
Post by mightymike » Wed Dec 09, 2015 9:31 pm
jnew
Post by jnew » Sun Dec 13, 2015 1:12 pm
Why is the baseplate upside down? Or am I nuts? :stars:
mightymike
Post by mightymike » Mon Dec 14, 2015 1:19 pm
I have no idea. Roger would know
Strat78
Post by Strat78 » Mon Dec 14, 2015 1:39 pm
I've noticed that some of these pickups have the "mighty mite" stamped on that side of the baseplate even when the pickup is assembled with the legs facing the right way. Maybe the seller put the plate this way just to show that it did have the mighty mite stamp? The guy is measuring the pickup wrong. The red wire should be tied off and the black wire soldered to the mesh, then measure the white against the mesh =12k or there a bouts? Oh, it looks like it was painted black, so it could possibly be a 8k mighty mite, originally a cream bobbin (never saw a black one measure that, makes sense now).
