EVH 5150 III: 50 vs 100 watt
MXR117
Re: EVH 5150 III: 50 vs 100 watt
Post by MXR117 » Wed Feb 27, 2013 9:51 am
Hi Henne,
do you call it the Henne-Mod? Lol.
Have you told Howard Kaplan about your Mod?
I will try it in the future, thanks for your Mod.
MXR
xhennex
Post by xhennex » Thu Feb 28, 2013 7:05 am
Hi MXR,
i would simply call it the 88-mod as the resistor is modified.
I know that Howard is following the thread on gearpage, but he won`t comment on it.
He wrote in a post and a pm to me that he cannot comment on any changes due to liability issues.
As you already disassambled the head, give it a try ;-)
There is no negative effect so far, during our last 4 hours rehearsal the amp was fine.
Regards,
Henne
MXR117
Post by MXR117 » Sun Mar 17, 2013 6:29 pm
Hi Henne,
i have done one mod to this amp!
R104 to 22K and raised C58 to .022 uF .I snipped the wima cap and soldered a new cap in place.
Now the Channel 1 and 2 are a lot better level-wise.
I`m glad that I have not sold this amp.
Now satisfied. :champ:
MXR
xhennex
Post by xhennex » Mon Mar 18, 2013 2:31 am
Hi MXR,
nice !
Do you have a tone sample or a video of your mod ?
I wanted to make a video of my mod yesterday but the sound quality was poor with the smartphone.
I found out that gain settings above 3 o'clock lead to a volume jump the other way round,
ch1 is louder than ch2 .... in this case I switch from ch1 to ch3.
Does your mod have the same effekt ?
Regards,
Henne
MXR117
Post by MXR117 » Mon Mar 18, 2013 10:01 am
Hi Henne,
the volume of Ch1/2 is Gain dependent. I never turn the gain above 12 o Clock because it is not clean anymore.
The amp is in the practice room so I can´t do a video.
The advantage of modding R104/C58 is that you don´t mess with the tone stack, changing R 88 does mess with the tone stack.
I`m not 100 % sure about that . Maybe someone experienced could comment on that.
http://support.evhgear.com/schematics/E ... matics.pdf" onclick="window.open(this.href);return false;
MXR
Images:
http://i1275.photobucket.com/albums/y46 ... 50e083.jpg" onclick="window.open(this.href);return false;
http://i1275.photobucket.com/albums/y46 ... 6a2b55.jpg" onclick="window.open(this.href);return false;
http://i1275.photobucket.com/albums/y46 ... a239b8.jpg" onclick="window.open(this.href);return false;
ROBIN L.
Post by ROBIN L. » Sun Oct 20, 2013 3:56 am
Blix wrote:New take on Panama with the Custom Custom with a Alnico 5 magnet:
http://soundcloud.com/amund-blix/panamacustom5" onclick="window.open(this.href);return false;
It sounds great.
Could you share your settings on the blue channel ?
Amberience
Post by Amberience » Sun Nov 10, 2013 4:10 pm
Hi all; great forum you've got here!! Been lurking a while. But wanted to ask about modding my newly acquired 5153-50w.
I am incredibly happy with the tone of the 50-watt, but I would like to maybe do one of these mods to even out the volumes. So far as I can tell there are three suggestions; changing R79 from a 10k to a 43k. Changing R88 to a 380k resistor. And finally MXR's modification of R104 to 22K and raising C58 to .022 uF.
Which one of these is the most recommended? As I say, I am really happy with the tone of the amp, and don't want to change it too much. I generally run the gain knob on ch1/2 at about 11 o'clock to keep channel 1 clean, and then I crank the volume to about noonish. The gain level is pretty much perfect for ch2, but this obviously gives me an INSANELY LOUD channel 2!! So this is what I want to fix.
I don't want to touch channel 3 at all. Thoughts?
Amberience
Post by Amberience » Tue Nov 12, 2013 8:49 am
double post.
MXR117
Post by MXR117 » Tue Nov 19, 2013 5:11 am
Hi amberience,
Technically the mod I described should be a little better (no mod of the tone stack).the volume difference between the two channels is Gain dependent.
I don`t understand that they did not build a 50 watt 3 Channel amp!!!!
I hate that!
I`m thinking about modding that thing further. Two small extra pots (Gain and Volume) switchable by two more relays.
This would be the best solution.
The gain in Ch2 with a Les Paul studio is too much.
The problem is to find a place for two pots and destroying the "look".
A dual ganged pot would be an alternative. But I could not find these pots (just mojotone sells them, shipping is too high for me 40 dollars shipping!!!).
If somebody has these pots......and wants to sell them or ships them cheaper.... :clap:
MXR
mightymike
Post by mightymike » Tue Nov 19, 2013 8:33 am
Have you tried valvestorm?
Amberience
Post by Amberience » Thu Nov 21, 2013 8:25 am
Thanks MXR :)
Amberience
Post by Amberience » Fri Dec 13, 2013 12:47 pm
Has anyone got any good clips of their mods? My tech says he can do it, and that it shouldn't be a problem. But I'm quite curious about how it will affect the tone of channel 2, and how clean I will really be able to get with channel 1.
andyg_prs
Post by andyg_prs » Sun Jun 29, 2014 1:44 pm
evh0u812 wrote:Sure.
Green/Blue channel-
10k voltage divider to 42k
This raises the clean level and increase gain slightly.
250pf mica on the 100k plate of the second triode.
Smoothes out top end on the blue channel.
Red channel -
Removed the 2 1uf cathode bypass caps C16 and C30.
Lowers the gain and makes the gain pot more useable across the range.
Replace 47pf on the PI with 100pf.
Still looking at the power supply filtering, but thats it for now.
Hi,
The blue channel on the 50 watt 5150III is my favourite channel on any amp. However, the volume jump green to blue and the excessive red channel put me off.
Based on your mods I might now buy one.
Can you please confirm the R number for the 10k voltage divider to changer that needs to be changed to 42k?
The same for the second triode and PI mods. Sorry, my only knowledge on this stuff is how to use the soldering iron.
Can you also please say how much the mod changes the nature of the green channel.....and the red?
In my ideal world, the red channel would just be a clone of the blue channel....
Sorry for all the questions but thanks in advance for any help you might offer.
Cheers,
Andy
andyg_prs
Post by andyg_prs » Mon Jun 30, 2014 9:15 am
MXR117 wrote:Hi Henne,
MXR
Hi MXR,
Is the mod just to add gain to channel 1? In that case channel 2 isn't changed at all?
If someone could find double ganged pots for the volume and gain controls for channels 1/2 or even the EQ, how would you need to wire them to make them operate?
Finally, the red channel. When I last tried the red channel I found it had way too much gain and was both too nasal and too treble-y for me. Do you have any idea how to make it more like the blue channel or just reduce the gain?
Sorry for all the questions but I have the option of buying a 50w EVH III second hand and am trying to work out if I could make it work for me....
Thanks,
Andy :)
Images:
EJSLPlexi
Post by EJSLPlexi » Tue Jul 29, 2014 12:31 pm
It sounds great.
Am i the only one that thinks this clip has WAAAYY too much gain?
there are a few guys i heard get a decent old school VH tone from these.
I had one for a few days and took it back.
I am not a fan of these amps for a old VH tone though. thats what old marshalls and metro kits are for :wink:
