mic'ing up a jtm45 - SLP question for anyone good with mics
hey guys
i have a quick question about the SPL the jtm45 puts out.
im using an condenser mic with a MAX SPL of 137.
can anyone tell me the max SPL a jtm45 can crank out at 10cms from the mic?
cheers
robml
cheers
robml
- toner
Sorry, I don't know the typical SPL of those amps but I seriously doubt it's anywhere near 137dB, even close-mic'ed! I would *guess* it's around 115 or 120dB max.
If you're worried about the mic, I'd suggest getting an SPL meter to be sure. Hopefully, someone else can confirm this but even so, each amp and speaker combo will be a little different.
hey 7string7string wrote:Rob, in addition to the close mic you should try moving the condensor back 5-10 ft. You can get a little more of the cab and room sound that way. Just keep movin it around till you find a good spot.
ive been mic'ing close with a sm57, and from 3 feet with the condenser - keeping the channels seperate left and right.. but im still having issues with phasing.. delaying one channel by several ms seems to help.. but the condensor 3 feet away does give quite a bit of room verb by itself. the sm57 by itself has quite a bit of a mid hump.
i see pics of condensers mic'd right up close on really large cabs and was wondering how they do it.. must be large mic pads and mic's with higher SPL rating than the speakers volume.
if my condenser can handle the jtm45 output volume i will make myself an adjustable mic pad (-10, -15, -20) and try it closer to the grill cloth
cheers
rob
- toner
RobML------> I am not sure what brand mic you are using....but on Neumann U87's there is a 10db pad which can put you usually where you need to be. Note: new U87's do not take as much SPL as the old ones (pre 86). Mine is a June 1970 I found and bought from Bearsville Studio's. I use my 1970 U87 right in front of my Marshall 100w SL with no attenuation. No problems at all. The Royer 121 is also a good mic for 4x12 cabs, I use them a lot. The U87 can take mid vol for rythem on the Marshalls without the pad sometimes as well.RobML wrote:hey 7string7string wrote:Rob, in addition to the close mic you should try moving the condensor back 5-10 ft. You can get a little more of the cab and room sound that way. Just keep movin it around till you find a good spot.
cheers
rob
On cheaper LDC like CAD, Audio Technica etc I have found they could not take the SPL from my Marshalls nor did they have a pad.
Cheers,
Eric
www.myopicvoid.com BAND WEBSITE.
more clips... http://www.myopicvoid.com/Gear.htm
http://www.soundclick.com/bands/pageart ... dID=579600
cheers
rob
Cheers,
Eric
Glad it worked well...Rode is a good brand!
Cheers,
Eric
Cheers,
Eric
- ericopp
First of all, make sure the cab is in the middle of the room - NOT backed up to a wall! The wall will become an extension of the cab - not what you want. Also, don't forget to take the wheels off!
Personally, I recommend the dynamic mic (SM57) right up close on the grill, point blank with the cone.
THEN, I like to have the cabinet miced with a ribbon (or condensor) on an outside back corner or back edge of the cab. When carefully blended with the stronger cone mic, you get nice woody "knock" that fills in the low-mid frequencies that the SM57 tends to miss.
"If I can't play my guitar through a Marshall I would rather not play my guitar at all." - Justin Hawkins - The Darkness
