How are you guys finding the fit of the 3PDT voltage option switch? If I install it so it toggles left to right the fit is okay (I'm using the 100W early style chassis). When I turn it so I can toggle up and down it jams into the power switch making it tilt a little. I thought about filing the holes a little to allow them to install without colliding.
How are you guys installing it? Any advice?
Darrin
3PDT Voltage Option Switch Mounting
