Should I rough up all solder connection points?
- Son of Skoora
Starting first build and in the past I've had to scuff most new metal surfaces for soldering. Do I need to scuff all the can tabs or tube socket tabs, posts on board etc.
Re: Should I rough up all solder connection points?
I only sand out the backside of the pots. If not, the solder wont bite...
