Sozo's in a guitar
Sozo's in a guitar
Most tone pots in guitars use a .02 cap. I was wondering if you could put a Sozo .022 cap on the tone pot of a guitar? I know Sozo caps are rated at 400V, and I don't know what volts the caps are rated at that are used on the tone pot of guitars.
What do you guys think of this? I just figured, hell if you're gonna put them in your amp, you might as well put them in your guitar.
- saborthw
SOZo's should work, many Guitar manufacturers use this these values
Ernie ball Axis Sport uses these values .22 400V this is also what was used in vintage Les Pauls. a more traditional choice may be Sprague Black Beauties or a Sprague Vitamin Q cap.
Allparts sells a Bumblebee reissue for around $ 60.00
I agree that your ears should tell you if a SoZo is right for your Guitar
Regards,
Scott
Regards,
Scott
Gear
59 LP, 1956 Custom Shop Strat, 50 wattt Mesa Stiletto Ace 1X12 combo , Protools OO2 R. 12XXX 68 Series Metro Plexi. 1960 BHW 4X12
So, the caps they use on the tone pots in guitars are rated at 400V?saborthw wrote:SOZo's should work, many Guitar manufacturers use this these values
Regards,
Scott
I just figured a Sozo cap would sound better than a cheap ceramic disc that has +/- 20% tolerance.
I just figured since everyone raves about the Sozos in their amps, then they should sound pretty good in the guitar.
So, if I went with Sozo, do you think it would be better to go with the "new" one or the "old" one?
I believe the common tone pot value for humbuckers is .02, right?
- Flames1950
Yeah, .022uF.
I tried some SoZos in my guitars, and yes they sound much better than stock. But I didn't think they sounded as good as the Auricaps I'm using now, or even Mallories in that application -- I decided maybe they needed to push some juice to get kicking and sound their best. Maybe John has some comments on this application he could contribute? (At the very least, think of the break in time on a guitar, 100 hours in an amp = how many at guitar voltage/current levels?)
- daniel
- sub
i read: (subject: tone cap)
SOZO: The only one alternative capacitor for Bumble Bee
I don't know.......i haven't Sozos
I tried Mallorys 150 then Orange Drops 716 (everybody said OD better)
........Hmmmmmm OD not bad, but i like better Mallory caps
and if Mallory better (like OD)....... I WANT SOZO caps
Sub
Sub
GibsonMarshallCelestion
- rockstah
wow break in time for caps in a guitar?Necrovore wrote:Flames, I was thinking about what you said about the break in time using Sozo caps in a guitar. Would breaking them in in an amp work or would the different voltages be incompatable? Interesting idea though.
seems like you could break them in faster if you just hooked a 9volt batter up to them and let em cook for a bit
- sub
