George, Help ! my Heyboer 100W PT have 2 extra wire !!!
Product sales, customer service, and announcements.
Souelle
Post by Souelle » Sat Dec 02, 2006 2:40 am
Hello George,
I just received your 100W kit, and I got a question about my Heyboer Power Transformer, the color doesn't match the Heyboer PT schematic. In fact, there's 2 extra red wire on the secondary.
What are they for, and can you let me know if I the following description is right ?
Primary :
orange = common -> Mains fuse
red = 120 -> Power switch
violet = is it 240 or 220 ? the schematic say 240, but in that PT description you made in the store, you have written violet 220 -> Cut
blue = same question -> Cut
Secondary
2 x blue = B+ Supply -> to standby
1 x yellow = CT -> to Filter Cap
2 x red (they are not on the schematic...) What are they for ? Do I simply cut them ?
1 x white = Bias supply -> to board (27k resistor - bias)
1 x green -> to ground
2 x Black (16G) = Heater Supply -> to V7
1 x Green/Yellow (16G) = CT -> to ground
Here's the infos written on the PT
100 WATT PT
HTS-6010-80
022798
Thanks a lot
Post by Flames1950 » Sat Dec 02, 2006 9:24 am
You've got one of the ones with two voltage options.....the two red wires are the (roughly) 500V leads, the two blues "should" have a red stripe and they're the (roughly) 400V option........
Check it out here with the daigram available:
http://store.metroamp.com/product_info. ... cts_id=458
Souelle
Post by Souelle » Sat Dec 02, 2006 11:36 am
The blue one don't have any red stripe, I'm confused...
Post by VelvetGeorge » Sat Dec 02, 2006 11:45 am
Sorry for the confusion. I've realized that I can't afford to stock so many versions of 100 watt PT. So I'll be adding these extra taps to th standard models. And I'll standardize the color schemes.
The two red wires are the lower voltage secondaries. if you don't want to use them, just shrink tube the ends and tie them off.
Souelle
Post by Souelle » Sat Dec 02, 2006 11:50 am
ok thanks...
So it means that I can used the red wire (to standby switch) if I prefer to run my amp at lower voltage and the blue one if I prefer the standard voltage, right ?
Post by VelvetGeorge » Sat Dec 02, 2006 11:52 am
Exactly!
VG
Souelle
Post by Souelle » Sat Dec 02, 2006 3:51 pm
ok, great, thank you so much !!!
Riscchip
Post by Riscchip » Tue Dec 05, 2006 4:34 am
Get the three position standby switch and wire it for both voltage settings! It's good stuff. 8)
mikeokc
Post by mikeokc » Tue Dec 05, 2006 11:34 am
Yep! just like having a Variac without blowing your amp up! :twisted:
Where are we going and why are we in this basket?????
Mike Fields
OKC
CosmicSPC
Re: George, Help ! my Heyboer 100W PT have 2 extra wire !!!
Post by CosmicSPC » Sat Apr 28, 2012 10:45 am
HI,
this si 1203-80 MS
HTS -8205
PT standup from Heyboer
from one hole : red, yellow, two green, two white, orange, purple
from second hole : two red, two blue, green/yellow, red/yellow
see picture below
PLASE could you hlep me with these wires? wire chart needed !
wires are completly different colored than used to or these tha are in metr amp guide...
THNX
(41.68 KiB) Downloaded 1687 times
